Can control page text change color based on a value?
Thu May 20, 2021 8:26 am
norcoscia offline
Hi, my ability to keep the Netatmo IOS app running on my old IPAD display has finally ended so I built a quick control page (thank goodness for Indigo IOS app).
I’m displaying various values that are pulled from Netatmo and wondering if I can change the color of the text based on the Netatmo value.
Example - Netatmo C02 value becomes greater than 900 parts per million - I would like to change the color of the text displaying the value to red (flashing would be nice but I’m sure that is not do-able).
Is this possible without creating Python code?
Thanks for any help!!!!!!
_______
Norm
Thu May 20, 2021 1:49 pm
Re: Can control page text change color based on a value?
Unfortunately, you cannot currently dynamically change the text color. You could try creating a couple of background images, one perhaps transparent and the other solid red, then place that behind the device state control. You would name the images something like:
then you could set them to reflect a variable value that you would alternate between having a value of an empty string and the string "red".
Thu May 20, 2021 2:12 pm
norcoscia offline
OK, thanks Matt - background is a good idea. I was just hoping it would be easy since I’m getting lazy in my older age :-)
_______
Norm
Wed Jul 27, 2022 5:42 pm
SearchCz offline
I dont know the Netatmo, but let's say that the CO2 level is a device state. You could display that device state on a control page in a subtle color, and ALSO display a variable of your creation that shows the same value in red, in the same spot as the other text, but higher in the z-order.
To make it work, you would set up a trigger to stuff the device state into your red text variable whenever the CO2 level rises above the ppm of concern. Also, another trigger so that, when the Co2 drops, you stick an empty (or blank) string into that same red text variable. When the variable is empty, the underlying text will show through. When the variable has content, it will be seen since it is higher in the z-order.
Check this video, showing two control pages side-by-side. The one on the right is a dynamic *list* of the on devices in my home. When I toggle a device off, I put the name of the device into the "offCaption" variable to get the white on black effect (rather than black on white).
https://www.youtube.com/watch?v=uGll0rOj1BM
Wed Jul 27, 2022 5:49 pm
norcoscia offline
Thanks I’ll check it out!
_______
Norm
Thu Jul 28, 2022 6:01 am
I like @SearchCz's approach very much -- but for simple things, like instances where the possible text values and color combinations are finite, I typically use Matt's approach to create simple PNGs with the values and colors I want to use. Where the possible text values are "infinite", I will usually use Python to create (and recreate) images on the fly using Matplotlib, Gnuplot, Pillow or something similar.
Here's a post that references a couple different approaches.
Fri Jul 29, 2022 8:19 pm
SearchCz offline
I’m over the moon just to have a control page that shows everything that is on. Something turns on, it gets added. I don’t have to scan or sift through 100 devices to locate the 12 that are on. I actually kind of surprised myself when I was able to make it work out …. a dynamic control page that only shows “on” devices, and adds devices as they are turned on. I’m a little bit proud of that.
Fri Jul 29, 2022 8:34 pm
ryanbuckner offline
Share a screen shot of this ?
Sat Jul 30, 2022 1:02 pm
SearchCz offline
Happy to share a few screen shots, These show my home with just a few things turned on. Then, as additional items are turned on, they get *added* to the collection. A tap on any item will toggle it. I don’t take away the items when they are turned off, but I have the *refresh* and *compress* options to bring the collection back to only showing devices that are currently on.
My house with a few items turned on
Lobby Mood gets turned off
Fireplace turns on, so it gets added to the collection
Assortment of devices that are (or recently were) turned on
These are all the same singular control page, changing as the status of devices in the home changes.
Sat Jul 30, 2022 1:13 pm
SearchCz offline
Maybe the video will give you a better sense of what the control page does?
https://youtu.be/mDxNLLggKkU
Sat Jul 30, 2022 2:09 pm
norcoscia offline
Really nice work on your control pages!!!!!
_______
Norm
Sat Jul 30, 2022 5:44 pm
SearchCz offline
Thanks! I still have the odd weirdo device pop up from time to time. Virtual devices that are remnants of past experiments.. might be purge unneeded devices, but that delete button scares me!
Sun Jul 31, 2022 5:50 am
SearchCz offline
My text values are extra Ed fro the devices and placed into variables via Python. I think that makes it well suited to “infinite” possible values?
Sun Jul 31, 2022 6:03 am
The way I think about it, I think so. One of my links above shows how to create an image with scrolling text; might this be something that could be adapted to your situation? In other words, not scrolling--but flashing?
Mon Aug 01, 2022 11:19 am
SearchCz offline
That sounds interesting …
