iOS Control Pages and Passwords
Sat Jun 06, 2020 2:56 pm
rustyhodge offline
I'd like to add control pages to the home screen on my iPhone, but when I do, it always prompts me for a password on opening them.
Are there any good workarounds for this?
Sun Jun 07, 2020 5:47 am
Re: iOS Control Pages and Passwords
I'm not seeing the same behavior. I just added an Indigo control page to my home screen (first loaded through Safari to create the shortcut). When I click the shortcut, the page opens without asking for a password.
Mon Jun 08, 2020 11:34 pm
rustyhodge offline
Do you use iCloud Keychain with your phone and desktop? It seems like if you save the password on the Mac, it will not require it anymore on the phone.
But when I add the control page URL to my wife's phone, it still wants the password. It seems to remember it until the phone is restarted possibly. Not sure how long, but it will remember it for a while. Just not permanently when only accessed on the phone.
rustyhodge offline
Also, I'm still running 7.2, maybe the newer version switched to cookie-based authentication and that's why it works for you?
Tue Jun 09, 2020 4:54 am
Hmmm. Not sure. I do use iCloud Keychain with all my devices (and I'm on Indigo 7.4). Also, I only tested when on my LAN; not sure what the result would be when attaching by WAN ( via VPN, etc.)
Sun Nov 06, 2022 12:44 pm
McJohn offline
iPhone iOs 16.1
We have the same problem as described in the first post:
At one iPhone all control pages are working perfect with Safari/saved to home screen, without asking for passwords again and again.
(This iPhone has also Indigo Touch installed).
But other users are always asked for the name and password. (It's a business solution).
Tried different solutions:
- http://Username:password@123.456.789.12 ... 0page%20II
(With this one the username and password are gone in the Safari link)
and every time when the user select the saved bookmark at the home screen, 10 seconds a black screen appears and he has to fill in all the credentials again.
- http://123.456.789.123:8176/controlpage ... 0page%20II
same problem and when this link is saved into the iPhone "passwords", only the IP address and port address is saved (also in the keychain of the Mac)
So, is there a solution to save the credentials of an Indigo Control page for use at the iPhone home screen? (without Indigo Touch).
Fri Nov 11, 2022 9:58 am
ryanbuckner offline
I'm happy to test this ... how do you create an indigo control page as your iPhone homepage?
Fri Nov 11, 2022 12:23 pm
McJohn offline
I don't know if I understand your question correctly but you can save any Safari page into your iPhone homescreen.
So, in the Indigo case: http://IPnumberIndigoServer:8176/yourcontrolpagename
John
Fri Nov 11, 2022 7:36 pm
Yes -- load up the web page you want to use and then select ---> Share ---> Add to Home Screen.
Fri Nov 11, 2022 9:08 pm
ryanbuckner offline
Ah ok it's just a shortcut. I am also prompted for a password when using this. Why not just use the app at this point?
Fri Nov 11, 2022 10:02 pm
Honestly, it depends very much on what you're looking to do. The Indigo Touch app works great (I use it all the time). I also use the Home Remote app to add certain Action Groups to my iOS widgets page (the ones I use daily). Home Remote is also capable of supporting Siri shortcuts--but I don't really use that feature too often TBH.
But more to the point, Indigo also comes with a built-in web server and -- if you're so inclined -- you can serve custom content (with or without credentials) that opens up a world of possibilities. The Indigo Web Server (IWS) architecture is quite powerful and a wonderful feature. Here's a sneak peek at a personal project (very much a work in progress) which runs on the Indigo Web Server. It uses a combination of a lot of different tools but essentially runs on HTML and JavaScript (the first two viewed here in macOS Safari, and the third on iOS). This site requires credentials to be entered on first load, but not again after that (unless the cache is deleted).
Screen Shot 2022-11-11 at 9.40.02 PM.png (321.83 KiB) Viewed 3423 times
Screen Shot 2022-11-11 at 9.44.26 PM.png (186.63 KiB) Viewed 3423 times
Sat Nov 12, 2022 8:56 am
ryanbuckner offline
That makes sense. So you're really using it for the content served from the web server rather than "Control Pages" proper.
Sat Nov 12, 2022 1:43 pm
Right. There are several folders under the /Web Assets/ folder -- I place nearly all of my code under the /static/ folder (which requires authentication) and certain select files under the /public/ folder (which doesn't). The latter is used for things like application icons and such.
