Error on load of images
Fri Jun 28, 2019 7:24 am
norcoscia offline
Hi, I have a control page that loads images from my security spy connected cameras using the command below
http://xxxx:XXXX@xxx.xxx.xxx.xxx:XXXX/++image?cameraNum=2&width=1400&height=900
The page displays both images w/o any issues but I get a continuous error in my log (see below) until I exit the page on my display.
  WebServer                       http://xxxx:XXXX@xxx.xxx.xxx.xxx:XXXX/++image?cameraNum=2&width=3840&height=2160 size too large: received 1454172 / max 768000
What can I do to keep the display the same size and not get the error. Is this a holdover from pre retina displays?
_______
Norm
Fri Jun 28, 2019 2:35 pm
Re: Error on load of images
What is the actual resolution (width & height) the camera is capable of?
The limit is there to prevent the CPU utilization from Indigo's web server from becoming too high. Trying to continuously pull down 1.5MB images can push the server a bit (and use a lot of bandwidth).
Fri Jun 28, 2019 4:28 pm
norcoscia offline
They are 3840X2160 (4K) 8 mp cameras - it should not be going through your server unless I messed it up - wall mounted display is set to only talk to my local indigo server. It works fine but fills up the log with errors anytime the page is displayed on the IPAD. I wanted that page to fill up the IPAD screen (2048 x 1536) with two of the cameras so with a border 1400X900 for each image is perfect.
Cameras and server are hard wired on the GiG ethernet so no issues with putting a strain on bandwidth.
_______
Norm
