- Posted on
Mon Apr 02, 2018 9:15 am
Different Computers
offline
How do I represent a device's battery level on a control page? I can't seem to find any built-in images to use for control pages for this. Indigo client has some custom support for displaying battery level for certain device types in the Item Detail window - would be nice if I could re-use or replicate something like that in a control page.
I use a forum script someone else came up with to automatically generate a graph of this. Bonus, when I add a new device that is battery powered, the script automatically adds it to the graph.
No credit to me, and sorry I forget who came up with it. One of the usual suspects, I'm sure.
- Code: Select all
#! /usr/bin/env python2.6
# -*- coding: utf-8 -*-
import sys
import matplotlib.pyplot as plt
import numpy as np
except ImportError, e:
sys.exit(u"The matplotlib and numpy modules are required to use this script.")
# =================== User Settings ===================
output_file = '/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/battery_test.png'
chart_title = 'Battery Levels'
x_axis_title = ''
y_axis_title = ''
background_color = '#000000'
chart_height = 4.5
chart_width = 6.15
font_color = '#000000'
font_name = 'Verdana'
font_size = 9
grid_color = '#888888'
grid_style = 'dotted'
show_data_labels = True
title_font_size = 9
battery_full_color = '#0000CC'
battery_caution_color = '#FFFF00'
battery_caution_level = 10
battery_low_color = '#FF0000'
battery_low_level = 5
# =================== kwarg Settings ===================
k_bar_fig = {'align': 'center',
'alpha': 1.0,
'height': 0.5,
'zorder': 3
k_grid_fig = {'which': 'major',
'color': grid_color,
'linestyle': grid_style,
'zorder': 0
k_plot_fig = {'bbox_extra_artists': None,
'bbox_inches': 'tight',
'dpi': 100,
'format': None,
'frameon': None,
'orientation': None,
'pad_inches': 0.1,
'papertype': None,
'transparent': True,
k_title_fig = {'fontname': font_name,
'fontsize': title_font_size,
'color': font_color,
'position': (0.35, 1.0)
bar_colors = []
device_dict = {}
x_values = []
y_values = []
# Create a dict of battery powered devices and their battery levels
for dev in indigo.devices.itervalues():
if dev.batteryLevel is not None:
device_dict[dev.name] = dev.states['batteryLevel']
if device_dict == {}:
device_dict['No Battery Devices'] = '0'
except Exception, e:
indigo.server.log(u"Error reading battery devices: %s" % e)
# Parse the battery device dict into X and Y values
for key, value in sorted(device_dict.iteritems(), reverse=True):
x_values.append(float(value))
y_values.append(key.replace(' - ', '\n')) # This line is specific to my install, as I name devices "Room - Device Name"
# Create a list of colors for the bars based on battery health
battery_level = float(value)
if battery_level <= battery_low_level:
bar_colors.append(battery_low_color)
elif battery_low_level < battery_level <= battery_caution_level:
bar_colors.append(battery_caution_color)
bar_colors.append(battery_full_color)
indigo.server.log(u"Error parsing chart data: %s" % e)
# Create a list of values to plot on the Y axis, since we can't plot on device names.
y_axis = np.arange(len(y_values))
# Plot the figure
plt.figure(figsize=(chart_width, chart_height))
# Adding 1 to the y_axis pushes the bar to spot 1 instead of spot 0 -- getting it off the axis.
plt.barh((y_axis + 1), x_values, color=bar_colors, **k_bar_fig)
if show_data_labels:
for ii in range(len(y_axis)):
plt.annotate("%3d" % x_values[ii], xy=((x_values[ii] - 5), (y_axis[ii]) + 0.88), xycoords='data', textcoords='data', fontsize=font_size, color=font_color)
# Chart
plt.title(chart_title, **k_title_fig)
plt.grid(**k_grid_fig)
# X Axis
plt.xticks(fontsize=font_size, color=font_color)
plt.xlabel(x_axis_title, fontsize=font_size, color=font_color)
plt.gca().xaxis.grid(True)
plt.xlim(xmin=0, xmax=100)
# Y Axis
# The addition of 0.05 to the y_axis better centers the labels on the bars
# (for 2-line labels.) For 1 line labels, change 1.07 to 1.0.
plt.yticks((y_axis + 1.05), y_values, fontsize=font_size, color=font_color)
plt.ylabel(y_axis_title, fontsize=font_size, color=font_color)
plt.gca().yaxis.grid(False)
plt.ylim(ymin=0)
# Output the file
plt.tight_layout()
plt.gca().spines['top'].set_visible((False))
plt.gca().spines['bottom'].set_visible((False))
plt.gca().spines['left'].set_visible((False))
plt.gca().spines['right'].set_visible((False))
plt.savefig(output_file, **k_plot_fig)
plt.close()
