- Posted on
Sat Jul 23, 2016 8:36 pm
offline
get started with INDIGOplotD:
1. step install plugin
2. if OS X >=10.8==> use matplot (in configure ), otherwise you need to install GNUplot
3. switch on sqllogger plugin for historical info ( for beginners use SQLITE) and in INDIGOplotD config
4. create first plot: menu/plugins/INDIGOplotD/Simple plot/
-- enter name / new /confirm (eg my plot1)
-- select device and state to be plotted eg thremometer/ temperature
-- select line type/ width/color
-- add txt etc
-- click on create, wait 30 seconds
-- click on show the plot should appear on the server screen -- not if you are on a remote indigo client
==> you will have now a device with name "plot1" (you can edit it later) and graphic files: plot1-minute.png and plot1-hour.png and plot1-day.png in your plot directory (default is ~/documents/INDIGOplotD/) these plots have a binning of 5 minutes/ 1 hour/ 1 day and go over 2 days/ 5 days /30 days you can changes that in edict the plot1 device
for more complex things:
1. define the data source
2. create an INDIGOplotD device
details:
-- in menu"INDIGOplotD/select data source"
-- select new / enter name / confirm
-- select state and measure (Average is probably the best for now, you could use min/ max count etc.. for eg max temp in a day ..)
-- confirm ==> then the plugin will collect the data from the sql logger and do any necessary calculations
== define as many sources as you like. in # 2 you will need these defined datasources to select them to create lines in a plot
2. create a INDIGOplotD device
- define size etc
- click on confirm
== now select the data sources you defined in step 1
- select line type, line key etc
confirm
(if you have expert mode enabled (top of the screen) you then can click on create and show)
you can add up to 100 lines to a plot using the left and right scale. they can be completely different lin/ log/ scale off set etc.
once you have mastered that you could add or subtract 2 datasources -- into one line eg 2 energy measurement and add them to a total.
hope that helps. if you need further help we could do an online one-on-one session.
if you have an older OS X you will need to install gnuplot. It is not difficult, but requires some steps. GNUPLOT is much better in resources usage by a factor of 10.
the functionality is 95% the same between matoplot and gnuplot in INDIGOplotD
