Show Sunrise/Sunset time on Control Page [Solved]
Fri Feb 12, 2016 5:27 pm
jalves offline
Just for fun I'd like to be able to show the current sunrise and sunset times on a control page. I see that Indigo has that information, but I can't seem to find a way to show it on a control page. I was going to put it into a variable, but I also can't figure out how to access the sunrise/sunset time. Am I missing something obvious?
Jeff
Fri Feb 12, 2016 5:42 pm
jalves offline
Re: Show Sunrise/Sunset time on Control Page
Never mind. Found my answer in a previous post here. Solution is to run this script:
set value of variable "sunrise" to "Sunrise: " & (weekday of (calculate sunrise) as string) & " " & (time string of (calculate sunrise) as string)
set value of variable "sunset" to "Sunset: " & (weekday of (calculate sunset) as string) & " " & (time string of (calculate sunset) as string)
end tell
Jeff
Fri Jun 14, 2019 5:43 am
Mark offline
Re: Show Sunrise/Sunset time on Control Page [Solved]
Yes, I've always used something similar to do the same. Such a simple thing with AppleScript. But how to fill "sunset" and "sunrise" variables using Python? I figured out how to fill my "date" variable:
# sets variable date to current date
# import
from datetime import datetime
# get the current date
tCurrentDate = datetime.now()
# convert date to desired format and set variable
indigo.variable.updateValue(1554385019, value=("Date: " + tCurrentDate.strftime("%a, %b %d, %Y"))) # "date"
Fri Jun 14, 2019 5:53 am
Mark offline
Scratch that. Found it elsewhere:
sunrise = indigo.server.calculateSunrise()
indigo.variable.updateValue(1728448011, value=datetime.strftime(sunrise, "%-I:%M"))
sunset = indigo.server.calculateSunset()
indigo.variable.updateValue(3027629, value=datetime.strftime(sunset, "%-I:%M"))
Fri Jun 14, 2019 5:54 am
Fri Jun 14, 2019 5:55 am
OK :D
Fri Jun 14, 2019 6:00 am
racarter offline
If you'd like some snazzy icons with the sunrise/sunset times, try this:
sun = u'\u2600 '.encode('utf-8')
moon = u'\u263E '.encode('utf-8')
nextSunrise = indigo.server.calculateSunrise()
indigo.variable.updateValue(<sunrise variable ID>, value=sun+nextSunrise.strftime("%H:%M"))
nextSunset = indigo.server.calculateSunset()
indigo.variable.updateValue(<sunset variable ID>, value= moon+nextSunset.strftime("%H:%M"))
Fri Jun 14, 2019 12:44 pm
Mark offline
Thanks all! I'll be bach!! I'm converting years of AppleScript to Python. Well, some of it. I'm using this opportunity to rid my system of code I don't really use all that much. "Less is more" is the new mantra!!
While I don't support Indigo's decision to dump AppleScript, I think I understand it, in part anyway. While I wish AppleScript was being supported by all developers, one can't really expect them all to stay onboard a train from which the engineer (Apple) has jumped off... :?
Fri Jun 14, 2019 3:46 pm
jalves offline
Rather than deal with scripts, I've moved on to simply utilizing the Clock Display plugin. Sunrise and sunset are one of the values this plugin provides when you create a new device.
Jeff
Fri Jun 14, 2019 10:44 pm
Mark offline
Nice.
Poor cat, lots of ways to skin it! :D
