- Posted on
Tue Jan 12, 2016 10:04 am
jay (support)
offline
- Site Admin
It would require using a script of some type to populate a variable, then you could show the variable on the control page. Roughly, the script would cycle through all devices, check to see if the onState was True, and increment a counter if it was. The you could set the variable. The script could be run periodically to update the variable (which might be grossly inefficient if you run it too often) or you could create a trigger for each device you want in the count to run whenever there's any change to the on state.
