[ANSWERED]: Web server root?
Wed Mar 04, 2015 2:11 pm
lochnesz offline
I tried to put my own html file in /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/templates/ as well as in /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/ , but I can't load the html page from a browser (undefined page requested). Is the web root somewhere else, or is there some magic needed in the web server to make this work?
Thu Mar 05, 2015 10:01 am
Re: Web server root?
Try putting it into:
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/static/
(or instead of static you can use css, images, js. You then access it via a relative URL using the same folder/path name.
Thu Mar 05, 2015 2:09 pm
lochnesz offline
Re: [ANSWERED]: Web server root?
:D Worked fine! Thanks!
