Can't get CP image to show
Sun Mar 01, 2015 1:13 pm
lochnesz offline
I am trying to add a battery status icon (LED icon) to my control page. The device is a Oregon temp/hum sensor with data collected by rfxtrx. When I select the battery level for the device in CP, I can see that the value is 10 when it shows as text. However, when I try to show it as a colored LED image, it isn't showing anything at all on the rendered web page, but I can see the default icon in the CP editor. I am sure it is just some obvious mistake from my point, but at this time I can't figure it out. I have attached a few pictures showing the CP editor, the file names and the rendered web page. As a demonstration I have both the icon and text version on the pictures.
Any thoughts?
Sun Mar 01, 2015 1:18 pm
Re: Can't get CP image to show
Try this:
You're very close.
Dave
Sun Mar 01, 2015 1:30 pm
lochnesz offline
Try this:
I tried that with no luck. The battery value seams to be from 1 to 10 since my current batteries are almost new, and the device battery level reported is 10. That is why I used numbers up to 10.
I just saw this in the log:
01 Mar 2015 20:26:15
WebServer undefined page requested "http://192.168.87.12:8176/images/controls/devices/battdot_40+on.png" from 192.168.87.10
WebServer undefined page requested "http://192.168.87.12:8176/images/controls/devices/battdot_40+on.png" from 192.168.87.11
So it requests "+on" when the value is 10?
Sun Mar 01, 2015 1:36 pm
lochnesz offline
Hm... +on shows the image, but doesn't give me the actual level. How can 10 equal to +on?
The logic goes by the device state.
So first, change 10 to 1, 20 to 2, etc. on the image filenames and see what you get.
If the actual value is 10, it won't be looking for "+on."
I can't remember, but Indigo may also have trouble with the underscore....
Sun Mar 01, 2015 1:42 pm
lochnesz offline
Changed to 1-10 and removed underscore, still not working and the log shows
The current value is 10, or that is at least what the rendered CP shows when I show it as a value.
Sun Mar 01, 2015 1:45 pm
RogueProeliator offline
This apparently is not so much a battery level as a "status" -- I assumed the exact same thing but was correct by other users having gone through this before; see this thread for more information on it.
However, it should show okay with a +10, +1 and +0 values as the battery level... that is what I have on my control pages. Dave was on the right track, I believe... you need that "empty value" placeholder in there AND you have to select it on the control page. Make sure your control page image selection is battdot_40+.png and NOT battdot_40.png.
Sun Mar 01, 2015 1:46 pm
Try deleting the control and placing a new one. The webserver is still looking for an image with an underscore in it (as per the log error.)
Sun Mar 01, 2015 1:47 pm
lochnesz wrote:
[I tried that with no luck. The battery value seams to be from 1 to 10 since my current batteries are almost new, and the device battery level reported is 10. That is why I used numbers up to 10.
Are you sure you did the exact image names suggested? In particular, do you have a base file named:
The + on the end of the base file tells Indigo to use the more advanced state value to filename heuristics.
Sun Mar 01, 2015 1:57 pm
lochnesz offline
As I mentioned in my first post, it is probably a obvious mistake, and it was...the + after the base file name (which I should have known). Now I got it to work, and I also learned that the Oregon battery status isn't what I thought it was.
Thanks for your help!
Sun Mar 01, 2015 2:04 pm
lochnesz offline
Confirmed that Oregon only has one bit to report battery status, so the two states are "battery good" and "battery low".
Sun Mar 01, 2015 2:05 pm
Terrific. Love the graphic by the way!
Sun Mar 01, 2015 2:11 pm
lochnesz offline
Thanks! Inspired by Oregon as you can see, made in Illustrator. I Replaced "channel" with "signal", which works great updated each time the sensor sends data.
Attached 340x300 icon here.
Cheers!
