[ANSWERED] Text colors in Control Page editor
Sat Jan 04, 2014 9:47 am
evansgo offline
What do the little colour boxes do at the end? I can obviously change the text colours, but they appear to "press" in and out and I cannot work out what this does? I was hoping that it would be possible to have the text one colour for true and another for false using these, but it doesn't appear to do anything....
Gareth
Sat Jan 04, 2014 10:37 am
Re: Text colours
the top one -shaded - should be disabled as there is no text to be configured
color button on the second line should pop up a color palette and you can select the color you like for your text
Sat Jan 04, 2014 10:42 am
evansgo offline
Re: Text colours
Thanks, yes I have seen that, but if you click on the colour button as well as bring up the palette, it appears to switch (or press in), so I wondered if this was to enable some sort of toggle on the selected colour.
Sat Jan 04, 2014 11:27 am
Re: Text colours
No, that is just to show you that the color well control is active and any colors you choose from the color palette will be set in the color well. There is no way currently to alter the color based on the true/false state of a device or variable. You can use custom images though, in which case the images can have anything you want rendered in them (including different color text).
Sun Jan 05, 2014 3:43 am
evansgo offline
Re: Text colours
OK thanks, understood - it would be good to give the colour two sates though :)
