Control Pages Attributes for Python Control
Thu Jul 25, 2019 11:27 am
wlpredrock offline
Re: Control Pages Attributes for Python Control
All my lights are controlled by switches outside the theater entry door. I plan to integrate them with the theater controller as you have, just haven't gotten around to it. I've got overhead cans, wall mounted lamps, stage/screen floods, and LEDs. All are dimmable and all are controlled with Insteon devices through Indigo. Should be fun when I get them all integrated!
Fri Jul 26, 2019 1:17 pm
mundmc offline
Are you guys on AVSForums? I’m “MinHeadroom” over there (joking reference to my freakish height and (originally) shallow basement).
I’m planning my 16:9 to 2.39:1 motorized screen masking system, of course operated through Indigo.
My screwing around with DC motors post here (and there) is my testing phase.
Mon Jul 29, 2019 12:17 am
wlpredrock offline
I didn't know it at the time, but I apparently purchased one of the last sold Carada Masquerade CIH Projection Screen Systems. The Boise, Idaho company closed its doors a couple of months after delivery. It was a great DIY system that works well. I was sorry to see the company go.
Tue Jul 30, 2019 12:15 pm
mundmc offline
I’ve heard of these! What kind of mechanism does it use?
Mon Aug 12, 2019 1:42 pm
wlpredrock offline
My Carada is a 120 inch diagonal screen. It uses a pulley and cable mechanism to move the two side masks up to 24 inches each horizontally. The controller is IR. There are 4 preset aspect ratios - Wide (2.35:1), 1.85:1, 16:9, and 4:3. It also has 4 dual controls to move the side masks together but manually, as well as 2 independent controls for each side mask. Sorry the company closed up shop; it is an excellent, simple design.
Thu Aug 15, 2019 9:47 am
mundmc offline
This is very much what I’m thinking of making. Pulleys, a stepper motor on an arduino, and a spring or a weight to keep some tension. Thanks for this!
Thu Aug 15, 2019 7:07 pm
wlpredrock offline
Sounds like it will work just fine. I may need to come to you for the plans if my Carada ever breaks!! :D
Thu Aug 22, 2019 11:59 am
mundmc offline
Be prepared for a kludgy fix :)
