Python script to not output below zero
Wed Apr 19, 2023 2:23 am
mwoodage offline
Hello,
I'm after some help with the following script, everything works well, but the output will go into a minus figure at some points during the day, but i'd like it to stop when it gets to zero.
Is there something i can add to the end of the script to stop it from going lower than zero?
Roof_Solar_Battery_Combined = int(float(indigo.variables[7675940965].value))
Immersion_Power = int(float(indigo.variables[2887052].value))
Battery_Power = int(float(indigo.variables[7292602006].value))
Available_Power = Roof_Solar_Battery_Combined - Immersion_Power - Battery_Power
indigo.variable.updateValue(3319680207, value=str (float(Available_Power)))
Thanks in advance
Martin
Wed Apr 19, 2023 4:56 am
Re: Python script to not output below zero
This is what you asked for:
if Available_Power >= 0:
    indigo.variable.updateValue(3319680207, value=str(float(Available_Power)))
But if you want it to log zero when the value goes negative, then you want this:
if Available_Power > 0:
    indigo.variable.updateValue(3319680207, value="0")
Wed Apr 19, 2023 5:29 am
Why all the conversions? You're converting your inputs to floats then to integers, then converting the output from an integer to a float.
Wed Apr 19, 2023 6:22 am
Joe has a good point. The code can be simplified:
Roof_Solar_Battery_Combined = float(indigo.variables[7675940965].value)
Immersion_Power = float(indigo.variables[2887052].value)
Battery_Power = float(indigo.variables[7292602006].value)
    indigo.variable.updateValue(3319680207, value=str(Available_Power))
or
Plus, all the conversions can have an effect on the outcome. Consider:
int(10.4 - 1.4 - 1.4)  # equals 7
int(10.4) - int(1.4) - int(1.4)  # equals 8
Wed Apr 19, 2023 6:50 am
mwoodage offline
Thanks Joe, Dave,
I've very little knowledge of python coding, i adapted something i'd seen / used before and just fiddled around with it until it worked. Really appreciate the simplified code, i've gone for this one and it seams to be working but won't know until the sun goes in tonight and stops producing power!
Out of interest, how does this example work?
Thnaks again guys for the speedy reply :D
Wed Apr 19, 2023 7:08 am
In Python, int() doesn't round the value, it truncates it. So int(10.8) yields 10. So:
int(10.4 - 1.4 - 1.4) is 10.4 minus 1.4 (equals 9) minus 1.4 (equals 7.6). int(7.6) equals 7
int(10.4) - int(1.4) - int(1.4) is 10 minus 1 minus 1 equals 8
Wed Apr 19, 2023 8:00 am
berkinet offline
Just as a matter of style and compactness. This
could be reduced to this
if Available_Power < 0:
    Available_Power = 0
Thanks to one of my favorite books: https://amazon.com/Elements-Programming ... 070342075/
Wed Apr 19, 2023 9:27 am
mwoodage offline
Wow, thanks Dave, Berkinet for taking the time to explain, I've still got so much to learn! :D
Not sure i still fully understand but i'll give the reduced scripts a try and see how they work,
Cheers all,
Martin
