Variables are kicking my butt
Posted: Wed Mar 22, 2023 8:59 am
I have yet to master the use of variables and conditions. I also do not understand programming, I am just using the software options.
I have a pump that I would like to have run at a set time if the outdoor temperature is above 50 degrees.
I have the outdoor temperature, at 5:30am, sent to "weather_temperature_F variable". this is working as it should.
At 5:45am I want the pump to run if temp is above 50 degrees and two other conditions. I have the following:
if Conditions match rules:
ANY of the following rules are true:
if variable. isHoliday is false
if variable. Onvacation is false
if variable Weather_Temperature_F is greater than value 50
I verified that the isHoliday and Onvacation are set to false. Today the temperature in the variable was 45 degrees and the pump was running.
What am I missing?
Thank you
What am I missing?
Thank you
