Value from system variable
Fri Dec 14, 2018 2:58 pm
farberm offline
I need to assign to a variable AirTemperature the value from a system deivice defined by the Pentair Plugin
-Air Temperature: The previous version of the plugin reported the system's air temperature to a variable. As air temperature is now a state of the 'System' device, the variable will no longer be updated.
The python script should be something like this but I am not sure:
AirTemperature = state (indigo.device (deviceID))
I know what the system device ID is that contains the value of the air temperature. Just do not know the syntax for the python script.
Fri Dec 14, 2018 4:56 pm
Re: Value from system variable
Should be something like:
device_value = indigo.devices[DEVICE ID HERE].states['DEVICE STATE NAME HERE']
indigo.variable.updateValue('AirTemperature', str(device_value))
Replace DEVICE ID HERE with the ID number of the Indigo device you're getting the value from (not in quotes).
Replace 'DEVICE STATE NAME HERE' with the exact name of the device state where the value is from (in quotes).
Strongly encouraged:
Replace the variable name 'AirTemperature' (in quotes) with the variable's ID number (not in quotes). Using a variable ID number will keep your script from breaking if you ever decide to rename the variable later on. The variable name will work (in quotes) but the ID is the preferred approach.
EDIT: adds string conversion to updateValue() statement.
Sat Dec 15, 2018 11:12 am
farberm offline
Ok almost have this correct. Seems like one error
Pool Controller ID 1867668806
PentairAirTemperature variable ID 558303937
Python Script is as follows:
device_value = indigo.devices[1867668806].states['airtemp']
indigo.variable.updateValue(558303937, device_value)
Device State name I think is airtime (see image below)
I still get the following error
Script Error embedded script: Python argument types in
VariableCmds.updateValue(VariableCmds, int, int)
did not match C++ signature:
updateValue(_VariableCmds {lvalue}, boost::python::api::object elem, CCString value)
embedded script, line 2, at top level
ArgumentError: Python argument types in
Screen Shot 2018-12-15 at 12.09.25 PM.png (251.24 KiB) Viewed 3900 times
Sat Dec 15, 2018 11:21 am
Apologies. Indigo stores its values as strings, so you need to convert it:
Sat Dec 15, 2018 1:09 pm
farberm offline
Great now working fine
