Multi-Colored Image associated with a Variable
Tue Dec 11, 2018 9:33 pm
Charles offline
Hi
I recall there being a way to associate an image with a variable state and then display that image on the control page in its associated "colored" state.
I would like to display the color of box (say blue, green, red) on the control page dependent on the condition of a variable.
For example, if a given variable House Temp is set to "On", I would display a red box. If House Temp is set to Off, a blue box would be shown.
I just can't seem to locate information on this topic on the wiki pages....unless that capability is not available any longer.
Any help would be appreciated. Thank You, :)
Tue Dec 11, 2018 10:38 pm
RogueProeliator online
Re: Multi-Colored Image associated with a Variable
This Wiki page describes how to do it:
https://wiki.indigodomo.com/doku.php?id=cp_custom_images
Long story short, you will create images:
And in the control page select the MyVariableImage+.png to display as the variable value. That Wiki page will go into more detail, but once you do it once you should have it as the basics are pretty easy after you see it in action.
Adam
