Variable - Last Change
Mon Oct 29, 2018 4:18 am
Colly offline
Hi all,
This is a variable and/or python question. How do I get the last changed time of a variable? Here is a simple example of what I'm trying to do for a few different scenarios, so once I figure this one I should be good for other use cases. This works for a device obviously but what is the variable equivalent for below?
motion = indigo.devices[1987458174]
timeDelta = datetime.now() - motion.lastChanged
if light.onState and timeDelta.seconds > 60:
        indigo.device.turnOff(1606772561)
Mon Oct 29, 2018 5:44 am
Re: Variable - Last Change
To the best of my knowledge, Indigo doesn't track this. For each variable, Indigo tracks:
folderId : 1863978771
readOnly : False
remoteDisplay : True
value : 1
I think you're going to have to track it on your own with another variable.
Mon Oct 29, 2018 6:24 am
You could achieve this with Timed Devices plugin (or possibly Timers & Pesters, not sure) if desired.
Create a timer that doesn’t do much except change whenever the device/variable it’s watching changes.
Then use your code above to watch the device time instead.
Mon Oct 29, 2018 6:29 am
Colly offline
Thanks Dave for your reply. I considered the 2nd variable but wondered if I missed something.
I'll give that a go as I already use that plugin.
Tue Oct 30, 2018 12:45 pm
checkout plugin "seconds since last change" ..
populates variables for seconds since last change, secs since previous change, and previous value for variables and or dev/states.
https://www.indigodomo.com/pluginstore/96/
Tue Oct 30, 2018 2:46 pm
Colly offline
Thanks Karl, I'll give that a shot!
