[SOLVED]How to email a variable....
Sat Dec 09, 2006 6:48 pm
BobRoss offline
Hello All
I have used Insteon to send mail and do things when receiving mail.
I have created a variable that increments on an action.
So here is the question, how at a specific time can I email myself the contents of the variable?
Bob
Loading up version 2 tonight - to give it a try.
Sun Dec 10, 2006 1:23 am
Re: How to email a variable....
Hi Bob,
Create a Time/Date Action for when you want the email sent. On the action panel choose the Execute AppleScript type and in the embedded field put something like this:
set messageText to value of variable "myCounterVariableNameHere"
send email to "my-phone@foobar.com" with subject "Variable Value" with body messageText
Regards,
Matt
Sun Dec 10, 2006 9:52 am
BobRoss offline
support wrote:
Hi Bob,
Regards,
Matt
Hi Matt
In 2.0 that works!! Now the bad news I think - I can't seem to get the TempLinc script to work in 2.0 - before I trouble shoot my self to death is that true??
The variable I was trying to send was the Temp :-)
Sun Dec 10, 2006 1:27 pm
The TempLinc script should work, but note there a new version of it in:
/Library/Application Support/Perceptive Automation/Indigo 2/Scripts/Attachments (Disabled)/
You should move that script up and over to the enabled Attachments folder and define the variable name and house code you are using at the top. Do not try to use the Indigo 1.8 TempLinc script.
Regards,
Matt
Sun Dec 10, 2006 2:02 pm
BobRoss offline
(No subject)
Duh!!!!!
Never thought to look in the disabled folder - I used the ver 1.8 -
Yes it works great now
Ver 2.0 - is VERY COOL
Bob
Tue Dec 12, 2006 9:31 am
Tmaxx offline
(No subject)
This is a great find !
That script should be put in the script section for us newbs !
Denny
Tue Aug 04, 2009 1:05 pm
hwilke01 offline
(No subject)
Aloha!
I've been using a Time/Date action to send me an email based on when sunrise is each day. Thinking about it, I've been considering the possibility of having additional variables added to this email something like this:
Today's forecast high temperature is: (Variable)
Sunset will be at: (Variable)
Local top stories are: (RSS?)
National top stories are: (RSS?)
I'm guessing this would require an insert of some sort of RSS feed? Is there a way to create an Apple Script to take like the first few lines of a news feed and then convert it into a variable and/or cut and paste into an email like this? I'm new at this, so I have no idea if this is even an easy or hard question. Many thanks in advance.
Hal W.
Wed Aug 05, 2009 7:00 pm
(No subject)
Off the top of my head I'm not sure about the RSS part (although I'm sure it is possible), but here is an example for the sunset:
set emailBody to "Sunset will be at " & (calculate sunset)
send email to "foo@foo.com" with subject "hello" with body emailBody
Sun Jun 17, 2012 10:58 pm
ckeyes888 offline
Would really like to get the top news headlines into some variables to have spoken
each morning. Anyone done or have any info on that?
Carl
Sun May 24, 2015 6:47 am
CraftGeek offline
Re: [SOLVED?] How to email a variable....
In version 6 of Indigo, can we insert a variable or device state directly into the GUI email form? Or do we still need to code it ourselves?
If we still need to do our own coding, where can a non coder turn to for all the info they need to create emails? Is there a document that lists all possible syntax that applies to an Indigo 6 email?
Sean
Sun May 24, 2015 11:32 am
Unfortunately, no. It's on our list to address, hopefully in the next major release.
The IOM docs document the sendEmailTo command.
Mon Mar 06, 2017 2:18 am
haakon offline
Re: [SOLVED]How to email a variable....
Hi, is this possible in Indigo 7?
If so, how should the variable be entered?
I am new to Indigo, so please excuse me if this is common knowledge.
Haakon
Mon Mar 06, 2017 4:27 am
Professor Falken offline
Probably the easiest way is to use the Better Email plugin. Install the plugin, then follow the instructions for creating an outgoing email device. Now a Better Email action list will appear in your possible actions.
The instructions for inserting a variable or device state are at the bottom of the pop-up in which you compose your email, but basically you offset the desired insertion with %%.
Hope this helps.
