Timestamp into variable - remove leading zero
Sat Aug 27, 2016 1:19 am
srkinard offline
I currently have a scheduled task where every minute it insets the current timestamp into a variable called HVAC_Time
Format string is %I:%M %p
This works, but it sticks me with the leading zero for any times other than 10/11/12.
What would be the best way to strip away that leading zero? I know from reading the notes that's like the standard Python result.
gives:
References to the variable are:
Python:      indigo.variables[517881967] # "HVAC_time"
Applescript: variable named "HVAC_time"
Suggestions? I had tried this but for some reason it would stop updating after a few minutes:
set thetime to the value of variable named "HVAC_time"
if (thetime begins with "0") then set thetime to text 2 thru -1 of thetime
set the value of variable named "HVAC_time" to thetime
Users browsing this forum: No registered users and 18 guests
