Use Variable as set point for temperature
Mon Apr 18, 2016 4:37 am
mlew offline
Hi All hopefully quick easy questions!
I am looking to set trigger that turns my heating down if the outside doors (front or back) are left open for a certain amount of time. That part i have no issue with but what i want to do is return the heating to last know set point, so i can see how to move current Temp set point into a variable but cant see how i move it back after. Is there a simple way to transfer a variable to a heating set point?
thank you
Mark
Mon Apr 18, 2016 11:06 am
Re: Use Variable as set point for temperature
You'll need a script for that. Something like this should work:
    previousSetpoint = int(indigo.variables[VARIDHERE].value)
    indigo.thermostat.setHeatSetpoint(THERMOSTATIDHERE, value=previousSetpoint)
except ValueError:
    indigo.server.log("Couldn't get a valid setpoint from the variable")
except:
    indigo.server.log("Error setting the setpoint to %s" % str(previousSetpoint))
Substitute the actual variable ID and the thermostat ID and that should be close.
Mon Apr 18, 2016 12:03 pm
mlew offline
Thanks Jay will give that a try
Sun May 01, 2016 11:49 am
aderrington offline
Just wanted to say Thanks Jay,
This works great for me.
Cheers!!
Andrew
Sun Nov 01, 2020 2:39 pm
sfcreatus offline
I would like to use a variable value to set the heat point of a thermostat. I'm totally new to scripts. I've tried using the script above (see post 4/18/16 from Jay) in an action (server action/script and file actions/execute script) pasting into the Embedded Python box. I've changed the varidhere to the variable name and the thermastatidhere to the device ID. On compiling I get an error: "embedded script:unexpected indent... around line 2 - "indigo.thermostat.setHeatSetpoint(128048856, value=Setpoint)". Any ideas? thanks.
Sun Nov 01, 2020 2:56 pm
Copy/paste into a forum reply the entire embedded script for us to see.
Sun Nov 01, 2020 3:21 pm
And please use the CODE formatting tags when you do that.
Sun Nov 01, 2020 3:42 pm
sfcreatus offline
Thanks to you both for a quick reply. Cutting and pasting from the previous post using code selection style...
except ValueError:
except:
Sun Nov 01, 2020 3:48 pm
Is that your actual code, or did you edit it to remove the IDs of the Variable and Thermostat?
Also, you're missing the "try" keyword, and missing indentation:
except ValueError:
except:
Sun Nov 01, 2020 4:31 pm
sfcreatus offline
Thanks FlyingDiver. I didn't realize "try" was a part of the code. I've corrected that. The following is the current script:
    previousSetpoint = int(indigo.variables[Therm].value)
    indigo.thermostat.setHeatSetpoint(128048856, value=previousSetpoint)
except ValueError:
except:
It compiles without error, however on running it, an error returns:
"Script Error Exception Traceback (most recent call shown last):
embedded script, line 7, at top level
UnboundLocalError: local variable 'previousSetpoint' referenced before assignment"
Thanks again.
Sun Nov 01, 2020 4:42 pm
That means the line:
Is failing. What is "Therm"? If that's the name of the variable, put it in quotes. But it's better to use the ID number of the variable, which is what the original code had.
This code is a little safer:
    previousSetpoint = int(indigo.variables[VARIABLEID].value)
except:
    return
except:
Everywhere it says *IDHERE should be the ID (number) of the device. You can easily get that by right clicking on the the device or variable in the appropriate list and select the Copy ID menu item.
Sun Nov 01, 2020 5:50 pm
sfcreatus offline
Gentlemen, thank you. Very much appreciated.
Is there a URL in indigodomotics' library that would have basic instruction on scripting?
Neal
Sun Nov 01, 2020 7:08 pm
