[ANSWERED]: Manually setting a variable's value
Sun Feb 21, 2016 10:07 pm
canalrun offline
I have a variable, MinLux, that I use as a comparison value against the luminance from an Aeon multisensor.
I would like to set the value of MinLux to 150.
Up to this point I've been opening a Python Shell and entering code similar to indigo.variable.updateValue(1234567, "150.0").
When I look in the Variable List window, I can see that the variable takes on the value 150.
Is there an easier way?
I am thinking of something like opening the Variables List window, right clicking on the variable, and entering the value in a pop-up text field.
Is there something like this?
On a related note: Have I entered the value for the variable correctly? What I am doing is comparing this variable to another variable that holds the luminance value from the Aeon sensor in the condition portion of a trigger to turn on a light (condition: if variable is less than variable) Will this comparison be performed as a numerical comparison? Even though I update the variable as a string value?
Barry.
Sun Feb 21, 2016 10:41 pm
jblackburn offline
Re: Manually setting a variable's value
Barry,
I've you tried double click on the value of your variable within the variable windows? You'll find what you need! :wink:
Joel
Mon Feb 22, 2016 5:03 am
shrxman offline
Also, you are storing the value correctly. You will need to convert it from a string to an int before you can do any arithmetic. I usually just convert it in the equation, as in int (var) + 150.
Mon Feb 22, 2016 11:15 am
canalrun offline
Re: [ANSWERED]: Manually setting a variable's value
Thanks both.
That was certainly easy !
Currently I am using trigger Conditions to compare (variable less than variable). It seems to be comparing numerically.
I will probably switch to Python. Then I will need to convert types.
Barry.
