Are Variable Values Case Sensitive?
Mon Dec 07, 2015 8:38 pm
CraigM offline
Mon Dec 07, 2015 9:54 pm
Re: Are Variable Values Case Sensitive?
The short answer: Yes, they are.
The long answer: I have created a variable called "Foo01" and set the value of that variable to "Bar". Consider the following script:
x = indigo.variables['Foo01'].value
if x == "bar":
    indigo.server.log(u"Equal.")
    indigo.server.log(u"Not equal.")
If you run it, you will get:
Dec 7, 2015, 9:37:35 PM
  Script                          Not equal.
"bar" does not equal "Bar".
But an interesting thing is the difference between "==" and "is". Consider this:
x = "Foo"
y = ''.join(["F", "o", "o"])
indigo.server.log(x)
if x == y:
indigo.server.log(y)
if x is y:
Will give you:
  Script                          Foo
  Script                          Equal.
  Script                          Foo
  Script                          Not equal.
Dave
Mon Dec 07, 2015 10:55 pm
RogueProeliator offline
I am pretty sure Python works the same way as the other languages I know better in that the == is a comparison on value where in "is" would be used as a comparison on objects (i.e. are two objects in memory the same object). Some languages optimize this for non-object types such as integers and they will return the same result. Still, when attempting to check the value of a variable I would suggest sticking to the == construct.
Tue Dec 08, 2015 4:52 am
Adam makes a good point that I should have put in my post. It's almost always better to use the "==" comparator when checking the value of a variable.
Dave
Tue Dec 08, 2015 9:59 am
And, just to complete the thought, to ignore case in the comparison:
if x.lower() == "bar":
This will work for most people, but if you're using a different character set it's less reliable.
Thu Dec 10, 2015 12:52 am
Cool, came across a problem at weekend with upper/lower matching - that's a good snippet to use.
