Number of lights turned on / open windows etc. - as a value
Tue Nov 10, 2015 2:19 pm
DrLaban offline
Is it possible to create a variable that is the number of lights turned ON ?
Or number of open windows etc.
If yes - what to do?
Tue Nov 10, 2015 4:25 pm
Re: Number of lights turned on / open windows etc. - as a va
(a) you could add 2 triggers for each device (if any change) and in a action:
trigger on: increment variable
trigger of:f decrement variable
But that would give you a very large number of triggers 2* the number of devices,
(b) Or a litte script you run 1/ minute that goes through a list of devices and counts.
you put this into an action of a schedule execute script (script and file Actions) and run it once a minute
list=[799923553,1996809732]  #  <-- here the list of devices you like to count if lights are on/.off  either use the ID's
list=["LeoCeilingLight","KonsCeilingLight"]  # or names
vari="lightsOn"
   indigo.variable.create(vari,"0")
except:
   pass
count =0
for nextLight in list:
      dev=indigo.devices[nextLight]
      if dev.states["onOffState"]: count+=1
indigo.variable.updateValue(vari,str(count))
Then the variable lightsOn will contain the number of devices that have onOffState =True
If the device does not have an onOffstate it will bomb and you should remove the device from the list
If you need further help let me know.
Tue Nov 10, 2015 5:13 pm
Karl, isn't there a dictionary (off the top of my head) for each of the built in device types (OnOff, Sensor, Thermostat, etc) that you could enumerate instead of manually maintaining $list[]?
Tue Nov 10, 2015 5:18 pm
Yes but onOff is not just for lights.
Tue Nov 10, 2015 6:17 pm
  719674580                                       switch for insteon modem:  accumEnergyTimeDelta("17532043"), accumEnergyTimeDelta.ui("17532043 seconds"), accumEnergyTotal("7.622"), accumEnergyTotal.ui("7.622 kWh"), curEnergyLevel("1.588"),
        :  curEnergyLevel.ui("1.588 W"), onOffState("True"),
  397127077                                                    StudyLights:  brightnessLevel("0"), onOffState("False"),
  1860008679                                                   SmokeBridge:  onOffState("True"),
Here some examples of devices and their states.. many have onOffState , but no light, on the other hand the switches can be used to drive lamps, they don't have "brightness"
Section on if dev.state contains "brightness" does not select properly.
I would manually maintain the list as you you probably will like to select certain lamps ...
If you have to many to fit into a line:
you can do
list+=[799923553, 123456,"deviceA"] # you could do device # or names or mix them if you like
if you want to see all devices and their current states, look at the the utility plugin http://forums.indigodomo.com/viewforum.php?f=184
Tue Nov 10, 2015 6:45 pm
You can enumerate the device types you want (indigo.Dimmer, indigo.Relay, etc).
Wed Nov 11, 2015 8:39 am
DrLaban offline
Thanx guys!
I will check this out :)
