[ANSWERED]: Count how long a device has been on for
Mon May 25, 2015 11:35 am
pegoto offline
I am trying to think through this but I am failing but I am sure the solution is simple.
How do I count how long a device has been on for?
What I am trying to do is to count how long the Nest has been on for, and if it reached, for example, 100 hours, txt me to replace the air filter.
Mon May 25, 2015 12:05 pm
ckeyes888 offline
Re: Count how long a device has been on for
One way, of many I'm sure, would be to have a variable hold the hour count that would be incremented
up every hour using a Schedule with the condition the Nest is running or whatever.
Carl
Mon May 25, 2015 1:33 pm
I don't know what communication you get from Nest, but I'd have a variable that stores the Nest_turned_on date/time, then every hour run a script basically saying 'if current time - nest_turned_on time is >100 then send me a text'.
Tue May 26, 2015 1:51 am
MarcoGT offline
As suggested, run a schedule every hour which increments by 1 (hour) a variable.
The schedule shall run only if NEST_ON=TRUE (depending on how you identify that device is ON)
Tue May 26, 2015 10:50 am
Use a timer device. For the first time, when the nest is on, manually start the timer. Create a trigger for when the nest goes off that pauses the timer. Create a trigger for when the nest comes back on that resumes the timer. Finally, create a trigger for when the timer expires that sends your email and restarts the timer.
Tue May 26, 2015 11:13 am
Re: [ANSWERED]: Count how long a device has been on for
Now why didn't we think of that?
Tue May 26, 2015 7:44 pm
ckeyes888 offline
Ha...only two solutions? Guys just aren't trying ;-)
Carl
Wed Jun 03, 2015 2:43 am
You could check the logger database for last change of device. But a trigger on that info would be more difficult.
Fri Jun 05, 2015 3:51 am
we could create a plugin where you could register devices / variables to be tracked for changes.
you then could use that info for trigger.
it would look like:
menue:
add == device : e.g. Nest
add == state: e.g. FAN
<confirm>
After that the state "Nest:FAN" in the plugin DEVICE "SECONDSsinceCHANGE" would show the seconds since last change.
Any interest?
in the background it would read once (at startup) SQLlogger for last change and then subscribe to any device/ variable change message in indigo and update its states accordingly.
Just an idea, don't know where the problems are..
we would need:
1. config menue setup to enable/disable subscription to tracking changes
2. track devices
indigo.devices.subscribeToChanges() # setup the subscription
def deviceUpdated(self, origDev, newDev): # called whenever a device gets updated
if origDEV ....:
3. track variables..
indigo.variables.subscribeToChanges() ## same for variables
def variableUpdated(self, origVar, newVar):
if origVar .... :
and then some logic to just filter out the ones we are interested in.
Fri Jun 05, 2015 7:32 am
Matt, Jay
(a) is there an UNsubscribe to "indigo.*.subscribeToChanges()"
(b) if indigo calls e.g. "deviceUpdated" and in the method a device is updated, will "deviceUpdated" be called immediately again or can we UN-sbubscribe while in deviceUpdated?
thx
Fri Jun 05, 2015 2:11 pm
There is currently no way for a plugin to unsubscribe to changes. Changing the device inside deviceUpdated() should cause another call to deviceUpdated(), but it will occur after the current callback has exited (it will not be recursive).
