[ANSWERED]: Variable List Empty
Sat Sep 20, 2014 1:20 am
rm2014 offline
From the documentation - it says Indigo ships with scripts that include variables? However my list of variables are totally empty?
How do I get that list of variables populated?
Sat Sep 20, 2014 7:59 am
Re: Variable List Empty
I believe it is like this: There are scripts that can create variables.
the scripts that come with indigo are in /Library/Application Support/Perceptive Automation/Indigo 6/Scripts and then in /attachements and in /attachments (disabled) .
they are applescripts
But that does not really help you.
you can create your own variables and use them in scripts or in triggers
best way to get started is do you a very simple script in an ACTION in an ACTION GROUP
here an applescript example where I use some variables and device informations;
   set frontDoor to on state of (device named "doorStatusFront")
   set kitchenDoor to on state of (device named "doorStatusKitchen")
   set poolDoor to on state of (device named "doorStatusPool")
   set backDoor to on state of (device named "doorStatusBack")
   set doorsTryCount to value of variable ("doorsTryCount")
end tell
if doorsTryCount > 4 then
      set value of variable "doorsTryCount" to "0"
   end tell
else
   if (frontDoor and kitchenDoor and poolDoor and backDoor) then
      end tell
      return
   else
         execute group "lockDoors"
      end tell
   end if
end if
and here how to use / set a variable (the first line) in a trigger for further actions / triggers in the script above.
Screen Shot 2014-09-20 at 8.57.24 AM.png (51.25 KiB) Viewed 2529 times
Tue Oct 21, 2014 2:43 pm
rm2014 offline
Hi Karl - never got to thank you for all the help here. This along with your excellent Fing plugin really helped me to understand the whole variable world. I have Fing now setup and understand variables now. I see what you mean now when you said the steep learning curve, but its all starting to make sense now :)
Cheers
Ross
Tue Oct 21, 2014 8:13 pm
Re: [ANSWERED]: Variable List Empty
Ross
you are welcome... I started about 18 months ago with my first little apple script. Nw my biggest plugin has 7000 lines.. real experts probably could do it with 100..
