[SOLVED]Automation and variable manipulation
Tue Feb 04, 2014 3:52 am
orangy offline
I'm working through my first set of triggers, variables, and action groups and I miss some actions. Probably I just didn't find it, but here is what I'm missing:
* variable -> device
-- action to set on/off device state to boolean variable value
-- action to set dimmer value (or any other integer value) to variable value
* action to increase/decrease integer variable value by custom value, not by 1, optionally setting min/max.
* (fun) provide several different phrases to speak, when trigger is executing actions, select one randomly
* display condition in the trigger's list in a separate column
Tue Feb 04, 2014 10:39 am
Re: Automation and variable manipulation
the following code will set the dimmer "NameOfYourLamp" to the value of your variable "testVariable"
theVar = indigo.variables["testVariable"]
theValue = int(theVar.value)  # convert the string e.g. 55 to integer 55
indigo.dimmer.setBrightness("NameOfYourLamp", value= theValue)
in your action group or trigger Action section - you enter this into
Server action / script and File actions/execute script
check out the examples in the wiki sectionshttp://www.perceptiveautomation.com/wiki/doku.php?id=indigo_6_documentation:plugin_scripting_tutorial
Hope this helps
set dimmer.tiff
set dimmer.tiff (111.79 KiB) Viewed 2416 times
Tue Feb 04, 2014 8:18 pm
Insert Device state into Variable
That can be done with a script.
Not practical since conditions can be arbitrarily complex. Perhaps a simple indicator if there's a condition present.
