Cycling through Fan Speeds w single button on Control Page
Mon Sep 13, 2021 8:20 am
sumocomputers offline
I have a GE Smart Fan Controller and using the Masquerade plugin to define OFF-LOW-MED-HIGH.
I would like have a single button on a control page that would cycle through the 4 states every time it is pressed.
Is this possible? Maybe this is Indigo 101, but never needed to do anything like this before...
Chris
Mon Sep 13, 2021 8:24 am
Re: Cycling through Fan Speeds w single button on Control Pa
Does the "Cycle Through Fan Speeds" action not work?
Mon Sep 13, 2021 8:33 am
LOL!!! I never saw that in there! Thanks for pointing out the obvious...
I did notice the cycle goes backwards from what I would expect (HIGH>MED>LOW>OFF>REPEAT) instead of (OFF>LOW>MED>HIGH>REPEAT), but maybe that is how analog fan controller remotes work...I don't have any of those.
Other than that, it works great!
Mon Sep 13, 2021 9:50 am
That is how the pull chain works on ceiling fans (at least in the US) - first pull high, next medium, next low, next off, etc. I modeled that command after the chain pull.
Mon Sep 13, 2021 10:00 am
This makes sense now that you say it.
I think my GE smart fan controller paddle switch does the reverse, which is what I have been using for quite awhile.
A feature request would allow for either direction :-)
