iTunes playback
Sat Sep 22, 2018 6:37 pm
rgspb offline
iTunes playback
I’m trying to figure out how to set up this scenario. I want iTunes to play a particular song through my HomePod and to repeat that song. I’ve been able to connect Indigo to iTunes but not sure where to go from there. Do I need to use Airfoil plugin? I guess I was thinking this is what the built in iTunes plugin was for.
Mon Sep 24, 2018 11:42 am
jltnol offline
Re: iTunes playback
Hey there
I don't have a HomePod, so won't be able to help you all the way with this, but you should also download the iTunesLocal Control plugin as well, as it has many more options than just the built in plugin does.
You'll need to set up a playlist with the song you want repeated, and from there, you can create an Action Group using the iTunes Local Plugin to play a particular playlist, and have it repeat forever..
Additionally, you can use this plugin to have iTunes select and de-select other AirPlay devices, and I'm assuming HomePod should be one of them.
Take a look at the iTunes Local Plugin, as I think it will help...
Mon Sep 24, 2018 2:32 pm
rgspb offline
Re: iTunes playback
Thanks, I'll give that a try!
Tue Sep 25, 2018 8:27 am
rgspb offline
Re: iTunes playback
That did it! That is an amazing plugin!! I'm not really sure the built in plugin is very useful at all, at least no one here seems to think so. I was able to do exactly what I wanted to do with the iTunes Local Control plugin.
Thanks again!
Thu Sep 27, 2018 11:38 am
Re: iTunes playback
It depends on what you want to do, and whether the instance of iTunes that you're running is on the local Mac or not. The plugin doesn't support playlists, but for typical control (play/pause/fwd/reverse/volume) it's been pretty solid for many years.
