Help with Indigo RESTful
Thu May 24, 2018 11:39 am
norcoscia offline
Hi, I just got my hands on a Flic hub and trying to use the Flic app to send the command(s) below :?:
The allowed options are shown in the second photo (within the Flic app.)
Is this possible or should I be doing it some other way?
_______
Norm
Thu May 24, 2018 4:10 pm
Re: Help with Indigo RESTful
Looks like it should work, but I think a key question is whether the system supports authentication.
Thu May 24, 2018 7:05 pm
norcoscia offline
Thanks Dave, this is what the screen looks like when I select POST - My problem is I don't even know what to read / look at to figure out how to do this...
I'm just not sure how to push the two parts (both lines) and how to get the curl statement before the http part to go over - talking about the curl -X EXECUTE part below?
curl -X EXECUTE http://192.168.1.16:8176/actions/Laundr ... rextension
_______
Norm
Thu May 24, 2018 7:23 pm
You shouldn't have to do the curl part at all, you should only have to send the URL. But you'll need to somehow send username and password--or turn off digest authentication (which is not recommended). The username and password (if it's able to do digest authentication) is likely going to be necessary to do anything in a secure way.
Take a look at this thread and see if there's anything of use. You might recognize someone. :D
Tue May 29, 2018 6:05 am
jaga01 offline
Hi - I have also received a Flic HUB and would like to controll my Fibaro plug with a flic button. Did you succeed with the function? Rgds Jacob
Tue May 29, 2018 7:16 am
norcoscia offline
No, I have not been able to make it work...... but I think it is possible, just beyond my skill level since I don't have a background in programming...
If you can figure it out pls let me know.
_______
Norm
Tue May 29, 2018 9:59 am
Different Computers offline
I have a couple of Flic buttons, but no hub.
All my Flic button presses to Indigo happen via shell scripts. Is that an option with the hub? I'm using a program called Hack with Flic to receive them on the Indigo computer via Bluetooth.
That said, it's a bit balky because the buttons tend to become unpaired/disconnected over time.
Tue May 29, 2018 10:14 am
norcoscia offline
The hub app is a bit different - I was also using the Hack app about a year ago but, agree -- it was not reliable enough - that is why I wanted to get the hub. I do not see a way to run a script on the new hub app. You can do something like that for android but it is not implemented on MAC OS.
Good list of what you can do with the hub here:
https://flic.io/applications
For the Mac OS I think the only option is HTTP but I cant figure out how to make it work....
_______
Norm
Tue Oct 02, 2018 3:53 pm
Frakke offline
Did you get it to work?
Tue Oct 02, 2018 3:54 pm
norcoscia offline
Nope - just sitting on my desk collecting dust - not even heavy enough to use as a paper weight - sigh....
_______
Norm
Sat Mar 23, 2019 2:36 am
Frakke offline
If anyone is interested I got it to work with the HTTPd plugin
Sat Mar 23, 2019 3:39 am
siclark offline
I'm using mine connected to a pi that then changes a variable in inidgo that triggers actions. It didn't need a hub and means that I can put a pi zero close to the flics rather than having them connect to the Mac. Works really well (other than when you try to install piBeacon on the same pi and break everything! I don't recommend that!!)
Happy to send details of anyone wants to do that. I find them more reliable than the nodon zwave remotes.
