sprinkler action
Tue May 22, 2018 8:29 pm
sprinkler action
I like to get the time duration of the zone that is running called by a regular indigo sprinkler action
    def actionControlSprinkler(self, action, dev):
the information available in the method is (indigo. server.log(unicode(action))
delayAmount : 900:
description : "device - zone1" on
deviceId : 1757238557
multiplierVarId : None
replaceExisting : True
sprinklerAction : ZoneOn
textToSpeak :
zoneDurations : []
zoneIndex : 1
in the method I like to have the duration of the zone action.! is there anyway of getting that, besides going through the logfile:
   Schedule                        rpi sprinkler
   Sprinkler                       scheduled "rpi-14-sprinkler" zone durations: 5.00, 2.00, 5.00, 6.00, 4.00, 6.00, 3.00, 2.00, 8.00
   Sprinkler                       turning "rpi-14-sprinkler" zone 1 on for 5.00 minutes
there is one prop in action : zoneDurations [] that is empty.
- how can that be set, and will it be used by the action
Have an rpi with pibecon setup that turns the relays on/off and has a display that shows zone info: accumulate time today, yesterday, this week, last week, this month, last month, active zone , rain amount .... date time, temp humidity ..
Only thing missing is the runtime time left for the current zone .
Screen Shot 2018-05-22 at 21.26.07.png (363.94 KiB) Viewed 2243 times
Tue May 22, 2018 10:24 pm
Re: sprinkler action
figured it out, but it is not simple
the sprinkler device -- NOT the ACTION -- has :
zoneMaxDurations : [20.0, 12.0, 30.0, 15.0, 10.0, 10.0, 10.0, 10.0, 10.0, 200.0]
zoneScheduledDurations : [19.9, 11.9, 29.9, 14.9, 9.9, 9.9, 9.9, 9.9, 9.9]
adding a device state "active sprinkler started", populated with
dev.updateStateOnServer("activeZoneStarted", datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S"))
and
if action.sprinklerAction == indigo.kSprinklerAction.AllZonesOff:
  dev.updateStateOnServer("activeZoneStarted", "")
in the action method.
then in the display action:
import datetime
dev    = indigo.devices[1757238557]
props  = dev.pluginProps
durations = dev.zoneScheduledDurations
zoneMaxDurations = dev.zoneMaxDurations
activeZone = int(dev.states["activeZone"])
zoneStarted = dev.states["activeZoneStarted"]
if len(zoneStarted) > 10:
   secDone = (datetime.datetime.now() - datetime.datetime.strptime(zoneStarted, "%Y-%m-%d %H:%M:%S")).total_seconds()
   minutes  = int(secDone/60)
   dur = min(durations[activeZone-1], zoneMaxDurations[activeZone-1])
   timeLeft = "%2d"%( dur - minutes)
   dur = "%2d"%dur
   aText  = "ActiveZone: #"+str(activeZone)+";    start:"+ zoneStarted[10:-3]+"; dur:"+dur+"; left:"+ timeLeft+" [min]"
   timeLeft =""
   dur = ""
   aText  = "Zones off"
gives:
"ActiveZone: #1; start: 23:13; dur:19; left:13 [min]"
will all be available in std pibeacon if you like to try..
Screen Shot 2018-05-22 at 23.36.55.png (364.44 KiB) Viewed 2228 times
Tue May 22, 2018 10:42 pm
if anyone is interested here the complete display script:
import datetime
zNames = dev.zoneNames
nZones = dev.zoneCount
#indigo.server.log(unicode(activeZone))
#indigo.server.log(unicode(zoneStarted))
#indigo.server.log(unicode(durations))
#indigo.server.log(unicode(zoneMaxDurations))
if len(zoneStarted) > 10 and activeZone > 0 and len(durations) == nZones:
   dur = "%2d"%(dur+0.2)
elif len(zoneStarted) > 10 and activeZone > 0 :
   dur = zoneMaxDurations[activeZone-1]
   aText  = "ActiveZone: #"+str(activeZone)+";  manual start:"+ zoneStarted[10:-3]+"; dur:"+dur+"; left:"+ timeLeft+" [min]"
   timeLeft =""
   dur = ""
   aText  = "Zones off"
onTime = "1"
if dev.states["activeZone"] == 0:
   onTime = "3"
   aText  = "sprinklers OFF"
tDay   = dev.states["minutesRunToday"].split(",")
yDay   = dev.states["minutesRunYesterday"].split(",")
tWeek  = dev.states["minutesRunThisWeek"].split(",")
lWeek  = dev.states["minutesRunLastWeek"].split(",")
tMonth = dev.states["minutesRunThisMonth"].split(",")
lMonth = dev.states["minutesRunLastMonth"].split(",")
line = ["" for ii in range(10)]
for ii in range(len(zNames)):
   line[ii]  = "%2d "%(ii+1)
   line[ii] += (zNames[ii][0:11]).ljust(11)
   line[ii] += tDay[ii].rjust(3)
   line[ii] += yDay[ii].rjust(5)
   line[ii] += tWeek[ii].rjust(5)
   line[ii] += lWeek[ii].rjust(5)
   line[ii] += tMonth[ii].rjust(6)
   line[ii] += lMonth[ii].rjust(6)
plug.executeAction("Display" ,   props ={
   "outputDev":"601124473"
  ,"device":"OUTPUT-Display"
  ,"restoreAfterBoot":"False"
  ,"intensity":""
  ,"repeat":"9999999"
  ,"resetInitial":"(0,0,0)"
  ,"scrollxy":""
  ,"showDateTime":"0"
  ,"startAtDateTime":"0"
  ,"scrollPages":""
  ,"scrollDelay":""
  ,"scrollDelayBetweenPages":""
  ,"command":'['+
      '{"type":"rectangle",   "position":[0,0,800,600],        "fill":[50, 50,50],       "display":"wait"}'+
     ',{"type":"text",        "position":[0,0],    "width":20, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf",       "text":" Zone    Min.:  Day YestD Week LWeek Month LMonth" }'+
     ',{"type":"text",        "position":[5,25],   "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[0]+'" }'+
     ',{"type":"text",        "position":[5,50],   "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[1]+'" }'+
     ',{"type":"text",        "position":[5,75],   "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[2]+'" }'+
     ',{"type":"text",        "position":[5,100],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[3]+'" }'+
     ',{"type":"text",        "position":[5,125],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[4]+'" }'+
     ',{"type":"text",        "position":[5,150],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[5]+'" }'+
     ',{"type":"text",        "position":[5,175],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[6]+'" }'+
     ',{"type":"text",        "position":[5,200],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[7]+'" }'+
     ',{"type":"text",        "position":[5,225],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[8]+'" }'+
     ',{"type":"text",        "position":[5,250],  "width":22, "fill":[0, 255, 0],     "display":"wait",     "font":"Andale Mono.ttf", "text":"'+ line[9]+'" }'+
     ',{"type":"text",        "position":[5,275],  "width":30, "fill":[255, 0, 0],     "display":"wait",     "font":"Arial.ttf",       "text":"'+aText+'",  "offONTime":[0, '+onTime+', 1]  }'+
     ',{"type":"text",        "position":[5,315],  "width":30, "fill":[255,255, 255],  "display":"wait",     "font":"Andale Mono.ttf", "text":"Outside Temp" }'+
     ',{"type":"textWformat", "position":[203,315],"width":30, "fill":[255,255, 255],  "display":"wait",     "font":"Andale Mono.ttf", "text":"%%d:340764825:Temperature%%FORMAT%5d [F]" }'+
     ',{"type":"text",        "position":[5,350],  "width":30, "fill":[255,255, 255],  "display":"wait",     "font":"Andale Mono.ttf", "text":"        Hum.  %%d:340764825:Humidity%% %" }'+
     ',{"type":"text",        "position":[5,390],  "width":30, "fill":[255,255, 255],  "display":"wait",     "font":"Andale Mono.ttf", "text":" Rain Today" }'+
     ',{"type":"textWformat", "position":[203,390],"width":30, "fill":[255,255, 255],  "display":"wait",     "font":"Andale Mono.ttf", "text":"%%d:57636140:currentDayTotal%%FORMAT%5.1f [in]" }'+
     ',{"type":"dateString",  "position":[10,425], "width":50, "fill":[255, 255, 255], "display":"wait",     "font":"Arial.ttf",       "text":"%a, %b  %d, %Y"  }'+
     ',{"type":"digitalClock","position":[550,425],"width":50, "fill":[250, 255, 50],  "display":"immediate","font":"Arial.ttf",       "box":{"on": "box", "width": "250", "height": "60", "fill": [0, 0, 0]} }]'
and the sprinkler device has the following states
Screen Shot 2018-05-22 at 23.40.34.png (67 KiB) Viewed 2228 times
and the device edit:
Screen Shot 2018-05-22 at 23.41.52.png (109.21 KiB) Viewed 2228 times
Wed May 23, 2018 9:46 am
Unfortunately, that's not necessarily going to be accurate since the schedule runtimes for each zone will likely be different than the max zone durations (which is a config setting Indigo uses to make sure that any zone never runs over that threshold).
A plugin can get schedule details, but if it does then it needs to handle all schedule management (on/off/pause/resume, durations, etc.).
As we've said before, Actions are not fully implemented in the IOM (not much really, only enough to allow custom actions for plugins) so getting the schedule details is not available yet. Finishing the IOM is pretty high on the priority list.
Wed May 23, 2018 10:09 am
Ok, after rereading your posts and code in the last post, it is actually be closer to correct than I first thought and probably as good as you can get... :lol:
Wed May 23, 2018 3:36 pm
reposted the code. this now also works for manual start (non schedule). in the plugin there is an auto off after max time
tried with various settings triggers schedule, manual etc seems to show the right time left
