Restarting Indigo server using "action"
Mon Nov 27, 2017 9:45 pm
Vig offline
Is there a way to restart the Indigo server via an action? Occasionally I find my USB connections unresponsive until I restart the server and using an action button would make that more convenient.
Tue Nov 28, 2017 5:07 pm
Re: Restarting Indigo server using "action"
I don't think so,
BUT you could record an "automator script" (key stokes)
Screen Shot 2017-11-28 at 16.50.35.png (244.88 KiB) Viewed 3143 times
duplicate, save as app
the run it from an indigo action .. some more steps needed
As for the USB not responsiveness
After I put a new usb3 card into my old MAC-pro 2008 I have no issues anymore with USB. Before I had to restart the Mac once every 3 days or manually plug the usb cables into different outlets.
Tue Nov 28, 2017 7:42 pm
Vig offline
kw123 wrote:
I don't think so,
thanks for the feedback Karl.
I actually run it all on a MacMini headless and was never able to get visual automator scripts that rely on mouse clicks to start unless the monitor is actively displaying the desktop.
As to the USB, since I don't have sufficient ports on MacMini I had to expand it and purchased Keyspan USA-49WG which is very reliable based on the reviews but for some reason once in a while I find the ports are not responsive unless I restart Indigo server.
Tue Nov 28, 2017 9:04 pm
I use the dongle to simulate the monitor, that script works on my headless mac-pro
Tue Nov 28, 2017 10:52 pm
Vig offline
That's interesting, what type of dongle do you use? That will be really useful for running scripts.
Thanks.
Tue Nov 28, 2017 11:44 pm
Bought some years ago on amazon. I believe any hdmi works.
Wed Nov 29, 2017 12:17 am
berkinet offline
Vig wrote:
... for some reason once in a while I find the ports are not responsive unless I restart Indigo server.
You might take a look at this page. Scroll down to the Answer.
If the USB Prober.app works for you (you should just need to open it and then quit it) you could run a shell script in an action to do something like...
open "/path/to/executable/USB Prober.app"
killall "USB Prober.app"
You could also dig into the USB Prober.app bundle and execute the binary directly.
Good luck. If you do try this, please post back with your results. If you don't have an Apple Developer account, PM me and I can send the app to you.
Wed Nov 29, 2017 10:17 am
Thanks.
This is the one I use: https://www.amazon.com/CompuLab-fit-Hea ... 00FLZXGJ6/
Wed Nov 29, 2017 10:36 am
Vig offline
berkinet wrote:
....You could also dig into the USB Prober.app bundle and execute the binary directly.
Thanks Berkinet! The latest USB log on Apple site is for 10.9 version of OS (I am running 10.12). I will try it to see if that works.
Wed Nov 29, 2017 10:37 am
Vig offline
FlyingDiver wrote:
Thanks.
that looks great, thanks FlyingDiver!
