Random errors...
Tue Oct 04, 2016 2:50 pm
P15-D24 offline
Random errors...
I run an action group to turn exterior lights on and off in the morning and evening. Generally it runs ok but I randomly get errors like no acknowledgment. But I also get Error "Pool Shed Pathway LEDs" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog) even though it runs fine at other times. Any ideas as to what is going on?
2016-09-30 06:00:00.233 Schedule AM Outside Lights On
2016-09-30 06:00:00.233 Action Group Outside Lights On AM
2016-09-30 06:00:00.500 Sent INSTEON "Pool Shed Pathway LEDs" on
2016-09-30 06:00:01.234 Sent INSTEON "Front Driveway LEDs " on
2016-09-30 06:00:01.521 Sent INSTEON "Front porch lights" on
2016-09-30 06:00:01.856 Sent INSTEON "Deck Step Lights" on
2016-09-30 06:00:03.594 Sent INSTEON "Deck Dog Light" on
2016-09-30 06:18:16.368 Received INSTEON "Fan & Light Master Bathroom" on
2016-09-30 06:18:16.369 Trigger Master Bathroom Auto Fan Off
2016-09-30 06:20:49.806 Received INSTEON "Stairwell Master" on to 100% (instant)
2016-09-30 06:22:14.937 Received INSTEON "Family Room Controller" on (button 3)
2016-09-30 06:31:16.309 Schedule Master Bathroom Auto Fan Off (delayed action)
2016-09-30 06:31:16.522 Sent INSTEON "Fan & Light Master Bathroom" off
2016-09-30 06:47:08.792 Received INSTEON "Fan & Light Master Bathroom" on
2016-09-30 06:47:08.793 Trigger Master Bathroom Auto Fan Off
2016-09-30 06:53:25.631 Received INSTEON "Family Room Controller" on (button 4)
2016-09-30 07:00:08.376 Schedule Master Bathroom Auto Fan Off (delayed action)
2016-09-30 07:00:08.604 Sent INSTEON "Fan & Light Master Bathroom" off
2016-09-30 07:00:15.589 Received INSTEON "Fan & Light Master Bathroom" on
2016-09-30 07:00:15.589 Trigger Master Bathroom Auto Fan Off
2016-09-30 07:06:15.149 Received INSTEON "Stairwell Master" off
2016-09-30 07:09:08.399 Schedule AM Outside Lights Off
2016-09-30 07:09:08.399 Action Group Outside Lights Off AM
2016-09-30 07:09:10.431 Error "Pool Shed Pathway LEDs" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
2016-09-30 07:09:16.635 Error "Front Driveway LEDs " off; send failed (no acknowledgment)
2016-09-30 07:09:22.753 Error "Front porch lights" off; send failed (no acknowledgment)
2016-09-30 07:09:28.882 Error "Deck Step Lights" off; send failed (no acknowledgment)
2016-09-30 07:09:36.404 Error "Deck Dog Light" off; send failed (no acknowledgment)
Running OS X 12.2.1 on 2018 Mac Mini, Indigo 2022.2
http://www.p15-d24.com
Wed Oct 05, 2016 7:17 am
P15-D24 offline
Re: Random errors...
Just had it happen again with different devices, the stairwell light and deck light. Then when I ran it again a few minutes later it worked fine.
Oct 5, 2016, 5:57:21 AM
Indigo Cocoa client authenticated (10.0.1.199)
Sent INSTEON "Stairwell Master" off
Error "Stairwell Slave" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Oct 5, 2016, 5:58:37 AM
Error "Pool Shed Pathway LEDs" on; send failed (no acknowledgment)
Error "Front Driveway LEDs " on; send failed (no acknowledgment)
Error "Deck Dog Light" on; send failed (no acknowledgment)
Oct 5, 2016, 5:59:45 AM
Received INSTEON "Stairwell Slave" off
Oct 5, 2016, 6:00:00 AM
Received INSTEON "Pool Shed Pathway LEDs" on
Error "Deck Step Lights" on; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Received INSTEON "Deck Step Lights" on (all linked devices)
Oct 5, 2016, 6:01:26 AM
Received INSTEON "Deck Step Lights" on (button 2)
Oct 5, 2016, 6:06:03 AM
Received INSTEON "Stairwell Slave" on to 100% (instant)
Wed Oct 05, 2016 9:46 am
Looks like in addition to that failure (PowerLinc not in module's database) you are also getting a lot of 'no ack' error messages. My guess would be either a signal problem or you have a module failing (most likely PowerLinc, but it is possible another module is failing and causing some systemic problems on the entire network). You might want to try temporarily plugging the PowerLinc into a different outlet on a different circuit. Quickest way to do that is with an extension cord. If the problems don't occur at all (or as frequently) then the Powerlinc is probably fine (and it is signal noise or some other module causing a problem).
Have you tried performing the Define and Sync operation again as the error log suggests? If the problems are intermittent that isn't super likely to help, because if the PowerLinc really wasn't in the module's link database then the commands would always fail to that module. That said, it wouldn't hurt to try it to see if it helps. You can copy/paste the event log results of the define/sync so we can see if anything looks suspicious.
Wed Oct 05, 2016 10:33 am
P15-D24 offline
I did do the define and link again. I have a Insteon Range Extender 2992-222 that is displaying a lot of network activity even when the nothing is happening. Suspect it may be failing.
Should this devices also be defined in Indigo? When I try to add the range extender I get an error that "no match found for device type ID 29 with firmware version 42" even after a hardware reset. My Smarthome 2443 Access Point did successfully add to Indigo.
If the problem continues after pulling the range extender I will start isolating devices trying to narrow down the bad module.
Thu Oct 06, 2016 10:22 am
The range extenders don't need to be added to Indigo (and as you saw Indigo doesn't recognize them). They automatically repeat commands without Indigo needing to be aware of them.
