Irrigation Reverse Order
Wed Aug 17, 2016 1:40 pm
CraigM offline
Is there a way to run an EZ Flora irrigation schedule in reverse order without creating Actions for each zone with a bunch of delays?
Instead of zones 1-2-3-4-5-6
I need 6-5-4-3-2-1
Wed Aug 17, 2016 2:57 pm
Re: Irrigation Reverse Order
Switch the wires on the controller to reverse the valve numbering?
Wed Aug 17, 2016 3:12 pm
CraigM offline
This isn't a permanent change. Only as needed in the PM of certain months
During the Summer, zones 4, 5 & 6 are in the hottest PM areas, so I would like them to get water sooner than later.
I'm trying to avoid:
Zone 6 action
-delay [zone 6 run time + 1 min]
Zone 5 action
-delay [zone 5+6 run time s + 2 min]
Zone 4 action
etc
Wed Aug 17, 2016 3:24 pm
Colorado4Wheeler offline
Just run two schedules, one with 0, 0, 0, 0, 20, 20, 20, 0 and the other to fill in where that one left off.
Wed Aug 17, 2016 4:46 pm
CraigM offline
The order needs to be zones 6-5-4...
Wed Aug 17, 2016 5:08 pm
There is no built-in way to switch zone order.
Thu Aug 18, 2016 5:05 am
johnpolasek offline
You might see if Berkinet's enhanced sprinkler management plugin might do what you want...
http://forums.indigodomo.com/viewtopic.php?f=22&t=7739
Thu Aug 18, 2016 7:52 am
I could probably easily add this functionality into Device Extensions which already adds other sprinkler functionality, I would have to look at it.
Thu Aug 18, 2016 8:34 am
ckeyes888 offline
Since zones can be started individually I found it not too difficult to have variables etc. handle
the timing and sequences, not using the EZFlora setup at all...with exception to the
longest time allowed.
This way I'm able to set specific times for each zone from a CP. The zone that starts after one has
finished can be set by a script or condition based on a variable.
Carl
