Write variables to a text file on a network share
Thu May 19, 2016 10:25 am
srkinard offline
I use Blue Iris running on a Windows box for all my security cameras, and one of the features it has is being able to overlay text onto the cam footage from a Macro (basically a pointer to a TXT file.)
I use a utility called Blue Iris Tools to do this with weather info and CPU/Mem/Disk status is the BI server, but I'm thinking I'd like to take certain device states and/or variables and overlay them onto the camera for that room.
Like my server room...I have a temp/humidity sensor in there, so I'd like to dump some information into a TXT file that is stored on the Mac Pro fileserver. The Blue Iris windows machine has a GPO that automatically connects it to a folder called "SharedMedia" so there's a central repository all of my systems can read and write to for file/data exchange.
What would be the best way to do this? AppleScript? Python?
For sake of examples, lets say I wanted to save some formatted info to this file:
/Volumes/SharedMedia/BlueIris/Macro2.txt
Here's what I'd like to pull data from (used Karl's Utilities to dump the device list and all)
1532285937                                       Arduino 1 - Temperature:  sensorValue("87.8"), sensorValue.ui("87.8 °F")
1750325374                                       Arduino 1 - Humidity:  sensorValue("35.0"), sensorValue.ui("35.0 %")
1757912877                                       Computer Room Server Power:  accumEnergyTimeDelta("1435801"), accumEnergyTimeDelta.ui("1435801 seconds"), accumEnergyTotal("394.555"), accumEnergyTotal.ui("394.555 kWh"), curEnergyLevel("553.353"),
        :  curEnergyLevel.ui("553.353 W"), onOffState("True")
Getting sensorValue.ui for each one except the AeonLabs SmartSwitch, getting curEnergyLevel.ui from that one.
and having the TXT file look like:
Room Temp:      87.8ºF
Room Humidity:  35.0 %
Power Use:      553.353 W
Thoughts on the best way to extract and format that data into a TXT file in the designated destination?
Thu May 19, 2016 11:30 am
Re: Write variables to a text file on a network share
Something like this should do it. Totally untested.
temperature = indigo.variables[1532285937].sensorValue.ui
humidity = indigo.variables[1750325374].sensorValue.ui
power = indigo.variables[1757912877].curEnergyLevel.ui
file = open("/Volumes/SharedMedia/BlueIris/Macro2.txt","w")
file.write("Room Temp:\t%s\n" %  temperature)
file.write("Room Humidity:\t%s\n" %  humidity)
file.write("Power Use:\t%s\n" %  power)
file.close()
You run that script as an action on a scheduled event, run as often as you want to update the file.
