Sending SMS
Mon Mar 28, 2016 6:44 am
Asconasny offline
Sending SMS
Hi
I want to receive a sms when a trigger runs.
Is there a easy way make a action sending this url?
https://telenormobil.no/smapi/3/sms?sen ... ESTMESSAGE
When i edit this url with my phone number and paste it in the web browser i receive a sms.
Regards
Asconasny
Mon Mar 28, 2016 7:38 am
MarcoGT offline
Re: Sending SMS
Well, maybe I misunderstood, but it would be enough with AppleScript to open this URL, something like:
tell application "Safari"
    open location "https://telenormobil.no/smapi/3/sms?sender=PHONENUMBER&password=s4653r&recipients=PhonenumbersId=1000000000&content=TESTMESSAGE"
    activate
end tell
Mon Mar 28, 2016 8:02 am
Asconasny offline
Re: Sending SMS
thanks!!
Spot on.
Something like this i was looking for.
and it works :)
regards
Asconasny
Mon Mar 28, 2016 3:58 pm
Re: Sending SMS
If you wanted to stay within Indigo (not use a call to an outside process like Safari), you could do it easily with a Python script. Something like this should work:
#! /usr/bin/env python2.6
# -*- coding: utf-8 -*-
import urllib2
URL = 'https://telenormobil.no/smapi/3/sms?sender=PHONENUMBER&password=s4653r&recipients=PhonenumbersId=1000000000&content=TESTMESSAGE'
response = urllib2.urlopen(URL)
response_text = response.read()
indigo.server.log(response_text)
The last line will print the response from the server to the Indigo log. If it's verbose, you can delete the last line, but you might want to know what happens in case of a failed send.
Dave
Tue Mar 29, 2016 3:44 am
Asconasny offline
Re: Sending SMS
Dave
I think it will be best to stay within Indigo but i get error using the script..
Script Error embedded script: <urlopen error [Errno 54] Connection reset by peer>
embedded script, line 8, at top level
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 126, in urlopen
return _opener.open(url, data, timeout)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 391, in open
response = self._open(req, data)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 409, in _open
'_open', req)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 369, in _call_chain
result = func(*args)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1189, in https_open
return self.do_open(httplib.HTTPSConnection, req)
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1156, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 54] Connection reset by peer>
Tue Mar 29, 2016 5:53 am
Re: Sending SMS
Do me a solid and try to run this one in its place:
import urllib2
URL = 'http://www.indigodomo.com'
print(response_text)
If it works, the problem you're seeing might be related to cookies or authentication required by the telenormobil website (which makes a fair bit of sense for your own protection.)
Let me know how you get on with the script above.
Tue Mar 29, 2016 7:35 am
Asconasny offline
Re: Sending SMS
Jupp,
Seems like its the telenormobil site. When i try the indigodomo it runs without errors.
anyway
thanks for the help.
regards
Asconasny
Thu Mar 31, 2016 6:39 am
ryanbuckner offline
Re: Sending SMS
Also, if you are using iMessage on your server:
-- send iMessage
tell application "Messages"
   set myid to get id of first service
   set theBuddy to buddy "+1555MYPHONE" of service id myid
   send "https://telenormobil.no/smapi/3/sms?sender=PHONENUMBER&password=s4653r&recipients=PhonenumbersId=1000000000&content=TESTMESSAGE'
" to theBuddy
end tell
