[ANSWERED]: Different results when running an action group..
Thu Dec 10, 2015 1:44 pm
P15-D24 offline
from the Action Group window and when calling it from a control on a web control page. I have an action group defined which calls a scene to turn off a set of lights. I added to the action group an second insteon instruction to set a keypad button to off. When I test the action in the Indigo window with "Execute All" it works. However if I run the action from my control page the scene instruction work but the added action for setting the LED button state doesn't work. The Event log doesn't look any different depending upon how the action is executed. Bug, feature or ????
Running OS X 12.2.1 on 2018 Mac Mini, Indigo 2022.2
http://www.p15-d24.com
Thu Dec 10, 2015 3:28 pm
Re: Different results when running an action group...
There should be no difference. Go ahead and copy/paste the Event Log results of both so we can make sure they look the same. Also run the test several times. It might just have been a coincidence that the Control Page group failed.
Thu Dec 10, 2015 8:52 pm
P15-D24 offline
Re: [ANSWERED]: Different results when running an action gro
Event log:
//Control page on, then off. LED button not set to off//
Dec 10, 2015, 6:43:09 PM
WebServer request to execute "Tester1" control #3 from 10.0.1.195
Sent INSTEON "PowerLinc Interface" on (scene 1 - Test Scene)
WebServer request to execute "Tester1" control #1 from 10.0.1.195
Sent INSTEON "PowerLinc Interface" off (scene 2)
//Control page on, then off from Action Group page via Execute All of selected Action Group Name (tester to scene off) LED button correctly set to off.//
Dec 10, 2015, 6:44:34 PM
Action Group Tester to scene off
Sent INSTEON "Family Room Controller" raw insteon command (2E 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Family Room Controller" raw insteon command (2E 00 00 09 C0 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Run it 5-6 time, behavior consistently repeats.
Thu Dec 10, 2015 10:06 pm
It looks like the control on your Control Page isn't executing the Action Group, it is just sending PowerLinc scene 2 OFF.
