Toggle ON/OFF Weirdness
Sun Jul 12, 2015 1:25 pm
PETStech offline
I have a problem. Any help would be appreciated.
For the Action Group:
"Roadside Lights ON/OFF"
             toggle “Porch & Garage Wall Lights"
             toggle “Roadside Floodlights"
for both toggle actions the ON toggle works but for one the OFF toggle fails to work, i.e., its light does not turn off--even though:
    1. OFF works when manually executed via the OFF button on the XPFM device's setup page [A], [C];
    2. lights on a lamp module on the same House/Device code (F9) turn (toggle) OFF while the lights on the XPFM do not;
    3. lights on another XPFM module (F10) in the same action group do toggle OFF; and
    4. the Event Log indicates that OFF was sent.
E.g.,
[A] Jul 12, 2015, 11:32:17 AM
  Sent X10                        "Porch & Garage Wall Lights" on
  Sent X10                        "Porch & Garage Wall Lights” off <—Lights DO turn off
Jul 12, 2015, 11:32:42 AM
  Action Group                    Roadside Lights ON/OFF
  Schedule                        _delayed_action_92
  Sent X10                        "Roadside Floodlights" on
[B]  Jul 12, 2015, 11:33:09 AM
  Sent X10                        "Porch & Garage Wall Lights” off   <—Lights DO NOT turn off
  Schedule                        _delayed_action_93
  Sent X10                        "Roadside Floodlights” off <—Lights DO turn off
[C] Jul 12, 2015, 11:34:41 AM
________
*Neither does Auto-off, after an 8 minute delay, turn off the device for an alternative, "Roadside Lights - ON (OFF after 8 )”
Mon Jul 13, 2015 9:56 am
Re: Toggle ON/OFF Weirdness
Unfortunately, you're using X10, which is very susceptible to power line noise and signal congestion. To compound the problem, X10 isn't a 2-way protocol, so all Indigo can do is tell your interface to send the command - we get nothing back about whether it was successful or not.
I suspect you're seeing sporadic signal issues. Check out the signal troubleshooting page for common causes and solutions to signal issues.
