[ANSWERED]House Shutdown Button
Tue Jan 06, 2015 6:15 pm
blysik offline
This is probably a common sort of use case.
I want to make a button on my remote that does a set of things:
1. Speak something through the Mac's speaker.
2. Turn on a device .
3.. After 10 minutes, shut off another device.
I can trigger can arbitrary python script on the Mac from a remote button easily. Is python the best way to do this?
Tue Jan 06, 2015 6:28 pm
Re: House Shutdown Button
You could if you wanted to - but you can definitely do it without scripting. Create the trigger and add an action that would turn on the device with an auto-off of 10 minutes. Then in the Speak text field at the bottom of the Action tab enter the text you want spoken. All done through the UI, no scripting required.
Tue Jan 06, 2015 6:31 pm
blysik offline
Ah, great. What's the best way to trigger a trigger from a command line?
Tue Jan 06, 2015 6:49 pm
Not following you...
Wed Jan 07, 2015 11:42 pm
blysik offline
Nevermind. I ended up just using a python script. Couldn't wrap my head around the other way.
