[ANSWERED]Sending Raw Command for Default Brightness
Thu Jul 31, 2014 9:08 pm
ckeyes888 offline
Has anyone been able to get the raw commands for default brightness to work?
Some time ago I thought I had the correct entries to do it but changing the D3 byte apparently
isn't correct.
Any help appreciated.
Carl
Raw Command.jpg (135.05 KiB) Viewed 3031 times
Fri Aug 01, 2014 2:59 pm
ckeyes888 offline
Re: Sending Raw Command for Default Brightness
Maybe default brightness can be set some other way, Python?
Carl
Fri Aug 01, 2014 8:06 pm
This looks like the original thread where this was discussed before. Your screenshot looks like what nsheldon there recommended. You might want to post on that thread to see if he (or anyone else) has any ideas.
Note I wouldn't expect this technique to work on pre-i2CS firmware modules.
Fri Aug 01, 2014 10:06 pm
ckeyes888 offline
Sounds like the "Send Raw Command" is experimental and undocumented?
Carl
Fri Aug 01, 2014 10:16 pm
I'm not sure what you are referring to (can you quote it?). Indigo's Send Raw INSTEON Command should work (no outstanding problems).
Fri Aug 01, 2014 11:46 pm
ckeyes888 offline
Just curious how someone would learn to use it.
Can't find anything on it in the docs.
Carl
Sat Aug 02, 2014 11:32 am
Are you wanting to know how to use the action/UI, or are you referring to trying to figure out what bytes to fill in for a specific the command?
The latter is something Smarthome has in their SDK and is a bit outside the scope of the Send Raw Command feature itself. Unfortunately, not all commands are documented and it can be difficult to know what commands work with which modules (and which firmware versions).
Sat Aug 02, 2014 12:51 pm
The menu item and action are in the documentation but because they are extremely advanced and as Matt points out you should have access to the INSTEON SDK to get the necessary data to use them, we didn't spend a lot of time on the docs. Anyone that understands the SDK is likely to understand those actions.
Sat Aug 02, 2014 1:57 pm
ckeyes888 offline
Gotcha, thanks guys. Have to dig into that more.
Carl
