Regular schedule vs holiday schedule
Tue Oct 01, 2019 7:53 pm
rgspb offline
I'm not real sure if i'm posting this in the correct forum but we'll see. I have a set of outside lights that come on at "Evening" 100%. At "Bedtime" they dim to 30% and then turn off completely later in the morning. For Halloween I'm putting some flicker flame LEDs in these fixtures. Since these bulbs aren't dimmable I want to skip the dimming at "Bedtime" and just turn them off completely. I'm just not sure what is the best way to set up a temporary schedule for these lights without completely changing my "Evening" and "Bedtime" action groups.
Wed Oct 02, 2019 9:01 am
Dual offline
Re: Regular schedule vs holiday schedule
I think you can disable your normal
Schedule on the 31st and enable it on the 1st. There should be a checkbox IIRC.
Fri Oct 04, 2019 9:59 am
rgspb offline
I think really what I'm looking to do is have a Condition attached to an item in an action group:
Turn light off if variable = Holiday
Brighten light to 30% if variable = Not Holiday
For now I'm just going to change that item in the list back and forth manually
Fri Oct 04, 2019 10:09 am
Have this script running every night at 12:01am:
# indigo.variables[1980497029] # "isHoliday"
# indigo.variables[1479852422] # "whatHoliday"
from datetime import date
import holidays
indigo.variable.updateValue(1980497029, value="False")
indigo.variable.updateValue(1479852422, value="None")
us_holidays = holidays.UnitedStates()  # or holidays.US()
if date.today() in us_holidays:
   indigo.variable.updateValue(1980497029, value="True")
   indigo.variable.updateValue(1479852422, us_holidays.get(date.today()))
That updates two Indigo variables - isHoliday (boolean) and whatHoliday (string).
Very useful.
I'm not sure if the holidays library is installed by default. You might need to use pip to install it.
Fri Nov 25, 2022 10:58 am
whmoorejr offline
I'm trolling the forum today looking for a better answer.... but this is how I'm doing it....
I have 6 nightly schedules.
(Reset the variables)
11:58 PM - set "SchoolDayToday" to true
11:58 PM - set "SchoolDayTomorrow" to true
(Set the variables)
12:01 S-----S: set "SchoolDayToday" to false
12:01 -----FS: set "SchoolDayTomorrow" to false
(Set the holidays from school calendar)
12:04 PM - if any "conditions list" : set "SchoolDayToday" to false
12:05 PM - if any "conditions list" : set "SchoolDayTomorrow" to false
From this point, any trigger that I want to operate differently on a school day versus a non-school day can use the above variable "SchoolDayToday" or "SchoolDayTomorrow" as a variable. This works well for morning alarm routines and stuff that monitor screen time usage, etc.
Another option for your case is to have a virtual button "Halloween Flicker Bypass Button" that bypasses your 30% dim trigger.
Add the condition to your bedtime trigger -> Bedtime: if Halloween Flicker Bypass Button" is off, then dim light to 30%
Create new trigger -> Bedtime: if Halloween Flicker Bypass Button" is on, then turn off light.
This is what my school calendar "conditions" look like, which I need to update every summer when the new schedule comes out.
School Holidays.png (107.93 KiB) Viewed 1705 times
Bill
My Plugin: My People
Mon Nov 28, 2022 5:55 pm
ryanbuckner offline
I do something similar to what Bill and @FlyingDiver do.
Variable 1939762834 contains a comma separated list of all the school holidays (days that school is closed in my County). A schedule runs at 12:01AM to run the following. Then I use the isSchoolClosed condition everywhere needed. For example, I don't need to turn off the lights and appliances in my kids' rooms at 10AM when school is closed, because they are probably using them (or still sleeping).
# contains a list of all the school holidays
holiday_list = indigo.variables[1939762834].value
today = date.today().strftime('%Y-%m-%d')
a = today in holiday_list
indigo.variable.updateValue(27794980, value=str(a)) # "isSchoolClosed"
Mon Nov 28, 2022 8:23 pm
GlennNZ offline
Along similar lines, there is a very simple python library holidays.
https://github.com/dr-prodigy/python-holidays
If you pip3 install, then can run scripts checking whether currently a public holiday in your location.
import holidays
us_holidays = holidays.US()
date(2014, 1, 1) in us_holidays
True
I use this to NOT turn on alarms in this case.
Worked flawlessly! (until python3 change, fixed by re-pip installing!)
Glenn
Tue Nov 29, 2022 8:35 am
jalves offline
So, running that script at 12:01, would you then set a variable to true if it's a holiday? And then use that variable when performing actions, or not performing actions, based on the state of the variable?
Jeff
Tue Nov 29, 2022 10:25 am
Post #4 has my complete script for setting the variable.
