Conditions not working as intended
Fri Jun 23, 2017 3:29 pm
CraigM offline
I discovered this by accident and its really causing grief with my schedules. Especially since I have this type of logic on almost everything in my house.
I have 2 irrigation schedules both at 6pm. The one who's conditions are met should be running, but they are BOTH running.
This should be satisfied for temps 100-101-102-103-104-105-106-107-108-109 [as they are between 99 and 110]
This should be satisfied for temps 110-111-112... [as they are greater than 109]
Why are they both being satisfied?
Fri Jun 23, 2017 3:49 pm
Re: Conditions not working as intended
Are those the only conditions? If not, take a snap of the entire rule editor control.
Fri Jun 23, 2017 3:53 pm
Ah - are your temps integers or floats? If they are floats, then 109.X (where X is > 0) would cause both to run.
Fri Jun 23, 2017 4:13 pm
CraigM offline
In this case the Wunderground plugin displays XXX.Xº [as does NOAA, and Oregon Scientific sensors]
So, are you saying the first one should be 99.9 and 110.0 to cover 100-109, and the second one needs to be changed to Greater Than 109.9, which will cover 110 and up?
I assume the dialog will accept decimals?
Fri Jun 23, 2017 5:19 pm
If the state you're selecting for the WUnderground device is in fact showing a degree symbol then I'm surprised it's working at all. The condition expects the selected device state to have either an integer or float.
Yes, the dialog accepts floats...
Fri Jun 23, 2017 6:13 pm
Just to chime in on the WU data.
Current Conditions - Temperature is linked to the custom device state 'temp'.
     temp : 80.7 (real)
     temp.ui : 81° (string)
By using float criteria, your conditions should work as you expect.
