Hi Sam,
One way of doing this is as follows:
Set up three variables: VarOne: false, VarTwo: false and VarCheck: 0 (zero).
Then setup three triggers: One each for VarOne and VarTwo so that any change in the variable runs an Action = Variable Action (modify variable) to increment VarCheck by +1.
The third trigger will check for a change in the light sensor's value and it will also run a Variable Action (modify variable) to increment VarCheck by +1.
Then setup a fourth trigger to run whenever VarCheck has any change.
Setup a condition as follows:
- Trigger Condition
- trigger_condition.png (39.07 KiB) Viewed 2366 times
Click on a + sign while holding the ALT key (the + sign changes to 3 dots) to added a compound condition as shown in the image above.
Hope this helps.
