Please help me with this "script error: tail"
Tue Jul 07, 2015 11:00 pm
T-Power offline
Hello All,
Can someone please help with this error message issue I am having.
[code]Jul 8, 2015, 12:44:00 AM
Script 2015-07-8 Events.txt
Error script error: tail: /Library/Application Support/Perceptive Automation/Indigo 6/Logs/2015-07-8 Events.txt: No such file or directory (1)
script error: tail: /Library/Application Support/Perceptive Automation/Indigo 6/Logs//code]
Thank you
MacMini 2.3 GHz Intel Core i7 16GB DDR3
Indigo Pro 2022.1 macOS Mojave 10.14.6
Wed Jul 08, 2015 12:43 am
Re: Please help me with this "script error: tail"
if this is a bash shell script
tail -100 '/Library/Application Support/Perceptive Automation/Indigo 6/Logs/2015-07-8'
gives you the last 100 lines
note the "'" around the file name It contains spaces
Wed Jul 08, 2015 10:52 am
T-Power offline
Thanks for the reply!
I dont think it is a bash script, it looks like the Indigo event log.
Thought this may be more obvious, how do I get rid of the continued error?
T.I.A.
Wed Jul 08, 2015 11:50 am
FlyingDiver online
Where are you seeing this error? If it's the Indigo event log, please repost it with the surrounding text, and use the proper CODE tags so it's readable.
Posting a list of the plugins you have installed would also be useful.
Wed Jul 15, 2015 9:20 am
T-Power offline
Hello again,
Sorry about the delay. The computer crashed with a kernel panic. I had to do a full recovery and so far I haven't seen the message return.
