[ANSWERED]Conditions not working
Sat Apr 19, 2014 9:51 am
BruceP offline
I have an Insteon motion detector in the garage. It fires a trigger to an I/O Link to sound a door chime when motion is detected. By itself, no conditions, it works as it should.
I have added the condition that "if device" "garage Light" on/off state "is off" However no matter what state the garage light is set the chime still chimes.
What am I missing?
Sat Apr 19, 2014 11:49 am
Re: Conditions not working
how do you test?
It took me some time to realize that the test button ignores the conditions and goes all the way through.
Sat Apr 19, 2014 12:29 pm
BruceP offline
Doing it the hard way. Walk in the garage with the light on and again with the light off. All the same. Chime sounds
Sat Apr 19, 2014 12:30 pm
could you post a screen shot and the log file. sometimes another set of eyes see the problem..
Sat Apr 19, 2014 12:40 pm
BruceP offline
Gladly, but I cannot for the life of me figure how to insert it into this forum
Sat Apr 19, 2014 2:02 pm
take a screen shot, then see this screenshot: do "choose file", "add the file"
here is how I would test it:
create a variable with value 0
test this variable if = 1, see if the trigger fires.
Untitled.tiff
Untitled.tiff (87.06 KiB) Viewed 5711 times
Sat Apr 19, 2014 2:25 pm
BruceP offline
Here it is
Screen Shot 2014-04-19 at 4.23.49 PM.png (40.67 KiB) Viewed 5709 times
Sat Apr 19, 2014 2:34 pm
BruceP offline
OK did the following:
Set variable static to 1
Set condition to trigger if variable = 1 - it fired
reset condition variable 2 while leaving variable at 1-trigger did not fire.
Here is a work around, but still does not explain why it will not work the original way.
Sat Apr 19, 2014 3:16 pm
I guess then the Garage Light is not off
Here is how you can try to find out the state(s):
- click on Plugins/ Open shell script
- type or copy paste
indigo.devices["Garage Light"].states["onOffState"] and hit (enter)
you will see what sets it comes back with (switch lights and run again)
I guess it will be False or True, which should be on or off.
May be you have a dimmer then it returns the % on
Sat Apr 19, 2014 3:30 pm
BruceP offline
It is off according to Indigo in the device list.
Ran script - light off reports false. Light on reports True
Switch is not a dimmer.
The plot thickens and I am at least getting my exercise. :)
Sat Apr 19, 2014 3:35 pm
in the action section add another action step:server action/ execute script enter
indigo.server.log(str( indigo.devices["Garage Light"].states["onOffState"] ))
this will put the true/false into your log file while executing the trigger.
if thats still is ok you will need to ask the experts..
[EDIT] you can also click on "insert into event log window"..
may be try if ALL of the conditions are met.
forgot the str() in the script..
Sat Apr 19, 2014 3:45 pm
BruceP offline
First off I got a script error, at least that is what it says, but this stuff is way above me.
However now it seems to be working. Cannot say why, but it did. Will be checking on this more tomorrow. SO is getting a bit upset with chimes and my running around.
Thanks mush for the help and will reply back here my findings tomorrow.
