display "next execution" of schedule items?
Tue May 23, 2017 4:31 pm
Professor Falken offline
There is a column on the schedule pane that shows the next execution of each schedule item. Is there a way to call this info and, say, pass it to a variable which could then be displayed on a control page?
Use case:
I'd like to show when timed lights are scheduled to next go on or off.
I could write some multi-step logic, using several variables and the Wunderground Astronomical plugin sunrise/sunset device states, but that could become unwieldy pretty quickly (hours and minutes are reported separately, and most of my schedules are a little off the actual sunrise/sunset, meaning I'd have to do some math on the device state, and account for crossing the 0 or 60 minute mark). It would be much easier to just use the "next execution", which Indigo seems to already know anyway.
Thanks.
Tue May 23, 2017 5:55 pm
Re: display "next execution" of schedule items?
You can get the next scheduled execution of any schedule using a Python script:
s = indigo.schedules[987654321] # some schedule ID
indigo.variable.updateValue(1234567, value="{:%H:%M}".format(s.nextExecution)) # some variable ID
So, run that script as often as you want the time to be updated in the variable (once a minute perhaps). You can use the standard date/time specifiers provided by Python to format the value in the variable to whatever you want.
Tue May 23, 2017 6:48 pm
Thanks for the quick response Jay. I can see this having several uses actually.
I defined a new variable, and filled in that new variable ID and the schedule ID into the script you posted. Unfortunately, I am getting this error when I test it:
Script Error embedded script: 'VariableList' object has no attribute 'updateValue'
embedded script, line 2, at top level
AttributeError: 'VariableList' object has no attribute 'updateValue'
Thanks.
Tue May 23, 2017 6:58 pm
Thanks.
Change 'variables' on line 2 to 'variable'.
s = indigo.schedules[702639074] # some schedule ID
indigo.variable.updateValue(283709108, value="{:%H:%M}".format(s.nextExecution)) # some variable ID
Tue May 23, 2017 7:10 pm
That worked like a charm. Thanks to both of you.
Tue May 23, 2017 8:10 pm
Dave,
Any idea how I could alter this to remove the leading 0 on hours 1-9?
I see there is a python command str.lstrip('0') which I think is designed to do that, but I can't seem to get it to work right.
Tue May 23, 2017 8:39 pm
Dave,
My guess is that you're probably trying to strip a numeric zero instead of a string zero. I broke this down a bit to make the steps more obvious, but you don't have to do it so incrementally.
v = "{:%H:%M}".format(s.nextExecution)  # This formats a datetime object as a string
v2 = v.lstrip('0')  # Strip a _string_ zero
indigo.variable.updateValue(283709108, value=v2) # some variable ID
ETA: I see you have a string zero in your post, I'm just guessing that you're trying to strip a numeric zero because this lstrip works perfectly for me.
Tue May 23, 2017 8:51 pm
You were exactly right, and that works perfectly. Thanks a lot.
Tue May 23, 2017 8:55 pm
Sweet. Glad I could help.
Wed May 24, 2017 8:22 am
Sorry, yeah, a typo in the script. I've fixed it above in case someone else finds the script useful.
Wed May 24, 2017 12:13 pm
Yes, I could see a few applications where I could use this script. Thanks.
I also really appreciate Dave helping me drop the leading zeros from the hour. Next I may see if I can adapt his trick for date displays ("Friday June 2, 2017" looks much better than "Friday June 02, 2017").
Tue May 30, 2017 6:02 pm
Dropping back by here in case anyone else finds this string later also looking to strip leading zeros off of single digit days and/or hours ("May 3" instead of "May 03", or "5:45 pm" instead of "05:45 pm") as I was. Dave's script above works, but it turns out there is a way to do it right from the date formatting.
I found this more robust list of date/time formats, and it includes options for both of those (%e and %l, respectively). These do seem to be working in Indigo. The one for lowercase am/pm (ironically the uppercase %P) doesn't work for me. I haven't tested any of the other ones on this list.
https://linux.die.net/man/3/strftime
Tue May 30, 2017 6:34 pm
Yes, that's right. Here's an example of the whole thing:
indigo.variable.updateValue(283709108, value="{:%A %B %e, %Y %l:%M}".format(s.nextExecution)) # some variable ID
Note that the fifth parameter is a lower case el ('L').
Tue May 30, 2017 6:50 pm
johnfdl offline
So I assume the 283709108 is the ID for the variable where we are storing the next scheduled execution, but where are we getting the 702639074 from?
Tue May 30, 2017 8:02 pm
702639074 is the Indigo ID of the schedule that we want to query for its next execution time.
