Schedule not working (any more)?
Tue Dec 06, 2016 1:38 pm
yassi offline
By the mid of November I've set up a schedule to turn on a lamp periodically by night.
It seems so, it isn't working anymore.
I've tried to find out (via the "utilities" plugin from Karl, the last records in the database are from November 17th.
Can one have a look at the screenshots, please?
I want it to run between 11.30pm and 5.30 am, every day, randomized and to turn on a bulb, then shut off.
Yassi
Bildschirmfoto 2016-12-06 um 20.31.00.png (64.06 KiB) Viewed 3050 times
Bildschirmfoto 2016-12-06 um 20.30.54.png (61.33 KiB) Viewed 3050 times
Bildschirmfoto 2016-12-06 um 20.30.48.png (88.48 KiB) Viewed 3050 times
records database
Bildschirmfoto 2016-12-06 um 20.30.37.png (32.4 KiB) Viewed 3050 times
Tue Dec 06, 2016 2:36 pm
Re: Schedule not working (any more)?
I don't understand why you have the conditional: your schedule will execute once every day randomly between 11:05pm and 11:55pm. Your condition will actually mean that once the randomization is applied, it will further restrict it so that it will only run if it's after 11:30. So I'm afraid your logic (and description) are probably not what you're actually looking for. Can you more specifically describe the intended behavior?
Tue Dec 06, 2016 2:43 pm
aldera offline
Since you have the schedule with a randomized start time of +- 25 minutes, the schedule could activate between 23:05 and 23:29 which would make it outside of the condition you set: 23:30-05:30. That's my guess.
Wed Dec 07, 2016 1:48 am
yassi offline
I think I've mada a mistake explaining it - and also the "Schedule" tab is not correct.
It should be so:
Schedule:
Time: every hour
Randomize by: let's say now 10-15 mins
Date: every day
Start: let's say today, never end
Condition:
between 11.30pm and 5.30am
Action:
Turn on bulb or whatever
Yassi
Wed Dec 07, 2016 10:38 am
Looks good to me.
Wed Dec 07, 2016 1:52 pm
yassi offline
Jay, please have a look at the new screenshot.
Should be fine now, what do you think?
Same condition (between 11.30pm and 5.30am)
Yassi
Bildschirmfoto 2016-12-07 um 20.50.39.png (89.16 KiB) Viewed 2921 times
