Restarting the Indigo Server
Fri Jul 15, 2016 8:24 am
Radjin offline
Is there a command or script I can use to restart the Indigo Server?
It's not rocket science...
Fri Jul 15, 2016 8:53 am
Different Computers offline
Re: Restarting the Indigo Server
OPEN(1)                   BSD General Commands Manual                  OPEN(1)
NAME
     open -- open files and directories
SYNOPSIS
     open [-e] [-t] [-f] [-F] [-W] [-R] [-n] [-g] [-h] [-b bundle_identifier]
          [-a application] file ... [--args arg1 ...]
DESCRIPTION
     The open command opens a file (or a directory or URL), just as if you had
     double-clicked the file's icon. If no application name is specified, the
     default application as determined via LaunchServices is used to open the
     specified files.
     If the file is in the form of a URL, the file will be opened as a URL.
     You can specify one or more file names (or pathnames), which are inter-
     preted relative to the shell or Terminal window's current working direc-
     tory. For example, the following command would open all Word files in the
     current working directory:
     open *.doc
     Opened applications inherit environment variables just as if you had
     launched the application directly through its full path.  This behavior
     was also present in Tiger.
     The options are as follows:
     -a application
         Specifies the application to use for opening the file
     -b bundle_indentifier
         Specifies the bundle identifier for the application to use when open-
         ing the file
     -e  Causes the file to be opened with /Applications/TextEdit
     -t  Causes the file to be opened with the default text editor, as deter-
so, what you need is
open /Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoServer
Fri Jul 15, 2016 10:48 am
This AppleScript will work, assuming you don't hit the 600 error:
   quit
end tell
# Give the server some time to fully shut down
delay 10
   activate
end tell
Fri Jul 15, 2016 11:33 am
Radjin offline
Perfect, thank you Jay.
