Setting schedule for holidays
Mon Jul 04, 2016 6:10 am
BruceP offline
On US holidays I wish to change some schedules vis variables , as we are home most on the day on a usual work day.
July 4 is an easy one since it is a set date.
Labor Day and Memorial Day are not so easy since the dates move. Is there a way to change a variable at 00:05 the day of a holiday?
I have yet to master any scripts, so I am sure this limits my choices.
Thanks all
Mon Jul 04, 2016 7:32 am
Colorado4Wheeler offline
Re: Setting schedule for holidays
Why not just have a variable that says "Holiday" that you can set via a button on a control page when you get up on that day? That way you can just trigger action groups that enable/disable schedules based on that variable. I do something similar but I have a "Holiday/Vacation Start" scheduled item and a "Holiday/Vacation End" scheduled item that enables and disables my various schedules - that way I can lay it out in advance and set the exact date and time I want it to start and end.
As far as "knowing" that today is a holiday and at 5 minutes past midnight (00:05) you want things to change then that will require scripting.
Mon Jul 04, 2016 8:02 am
johnpolasek offline
Or if you want to get fancy, you could create a file that you update once a year which lists the holidays YOU observe and their dates for the upcoming year and have a script to read the file at midnight + 1 second each night and do whatever setup you want if a holiday date matches now()... the problem with using an internet source to get the dates is that the sources list of holidays may not coincide with the days you observe... case in point, Texas A&M does not observe Labor Day as a holiday; but pretty much every holiday list does.... And at a company I once worked for in Louisiana, the Monday after the opening of alligator season WAS a company holiday because so many of the operators were out checking their lines.
Mon Jul 04, 2016 12:52 pm
I realize that the OP said he has yet to master scripts, but I also offer that there is a Python Holidays package. It has a few more holidays than you might want (which can easily be ignored), and provides examples to show how you can add additional custom holidays (like Alligator season.)
>>> import holidays
>>> from datetime import date
>>> date(2016, 7, 4) in holidays.US()
True
Screen Shot 2016-07-04 at 1.40.08 PM.png (76.59 KiB) Viewed 5567 times
Mon Jul 04, 2016 1:17 pm
Good find, Dave.
Install the holiday package:
sudo pip install holidays
Create a variable called "isHoliday" (or whatever you want, really).
Create a schedule that runs this script right after midnight. Change the ID in the script to the one for your variable.
# indigo.variables[1315142287] # "isHoliday"
import holidays
indigo.variable.updateValue(1315142287, value="False")
us_holidays = holidays.UnitedStates()  # or holidays.US()
if date.today() in us_holidays:
   indigo.variable.updateValue(1315142287, value="True")
Mon Jul 04, 2016 2:48 pm
If you want to also grab the name of the holiday, you can use:
indigo.variable.updateValue(another_variable_ID, us_holidays.get(date.today()))
Tue Jul 05, 2016 5:45 am
Japple55 offline
I, too, was rudely reminded yesterday morning that I needed to set up a holiday schedule. Not being a coder, I took a more simplistic approach by just using Indigo's schedules. No iCal, python, or Applescript needed. It seems so simple that maybe I'm missing something...is there any reason this won't work going forward?
1. Create the variable "holiday."
2. Create a schedule to set the variable to "true." (Holiday Mode - Start)
3. On the Conditions tab, add a match rule for each date whose holiday you wish to observe. (mine only has 9)
3. Set the schedule to run every day at 12:01 AM to test for a holiday match.
4. Create another schedule to run every day at 11:59 PM to reset the variable back to "false." (Holiday Mode - End)
Granted, the condition dates need to be updated once per year for those holidays that aren't static, but I set a calendar task to remind me before the end of the year.
Jim
Tue Jul 05, 2016 5:51 am
Jim
I think that this would work well. The only downside is that part about remembering to update the holidays that aren't static. I'm lucky if I remember to put on pants.
Dave
Tue Jul 05, 2016 5:56 am
Japple55 offline
Hilarious, Dave! :)
Tue Jul 05, 2016 5:58 am
Hilarious, Dave! :)
I had to double-check, but I remembered.
Tue Jul 05, 2016 9:53 am
I believe if you move the logic back to the schedule itself, you can probably create a recurring event that only fires on the specific date you're looking for. This only works with holidays that are calculable (and no weird exceptions), but I think most are.
For instance, Memorial Day in the US is defined as the last Monday in May. You can create a schedule that runs every year on that day thusly:
  • Set the Time of the schedule to 12:01
  • Set the Date to "on the last Monday"
  • set Repeat to Every 12 months
  • set Start on to May 1st 2016
If you then inspect that schedule in a python shell, you'll see the nextExecution property is set to "2017-05-29 00:01:00".
I'm not positive that every conceivable scenario is possible with just the UI, but I suspect most are.
Tue Jul 05, 2016 11:21 am
RogueProeliator offline
The biggest issue is likely Easter if that applies to each person's particular religious calendar. I believe I've read that it is based on lunar calendar/cycles, but based on the dates each year I am about 99% sure this is a conspiracy and it is actually based on a roll of a magic 8-ball somewhere.
I started to write a calendar plugin a while back... with this Holiday module, this could be super simple. Hmm...
Tue Jul 05, 2016 4:24 pm
BruceP offline
Wow, thank you all.
We had a little medical emergency in the family and just returned to look at the posts. Wonderful suggestions.
Time now is tight for this issue, but please understand I will be looking at this soon.
Again thanks.
