[SOLVED]: Issues with days of week
Thu Feb 04, 2016 9:29 pm
roquej offline
Implemented a simple watering the plants approach described in another thread. However, ran into a problem. It doesn't matter what you pick for the day of the week, a single day or multiples, the schedule always triggers the next day. If you see the enclosed screen grabs, the day of the week is set for Friday (02/05), but the "Next Execution" is set for today (02/04). This only happens for the day of the week and only of you manually set the time. If you leave the time alone and select the day of the week you want, it works as expected.
Bug or am I missing something?
Thank you in advance.
JP
Screen Shot 2016-02-04 at 10.18.12 PM.png (95.54 KiB) Viewed 2371 times
Screen Shot 2016-02-04 at 10.19.27 PM.png (125.08 KiB) Viewed 2371 times
Thu Feb 04, 2016 11:54 pm
ckeyes888 offline
Re: Issues with days of week
I believe the grayed out days are the ones actually selected, not the white ones.
Seems backwards to me.
Carl
Fri Feb 05, 2016 4:57 am
Carl
Carl's right. Technically, they're not grayed out as the text of the button is black (and not gray). But I agree that it would be easier if the selection were more obvious--like setting the buttons to a color or had seven checkboxes or something like that.
By the way, after you select it, you can see on the trigger list when your trigger will fire: SMTWT-S.
Dave
Fri Feb 05, 2016 10:46 am
Re: [SOLVED]: Issues with days of week
That's correct, the darker ones are the ones selected. These are standard small Cocoa buttons which show state. As an example, if you select the Sunrise option under time, the Customize... button will enable and you'll notice it's white (unselected) - when you click and hold, it turns dark (selected). All cocoa buttons are white when unselected, and colored somehow when selected (either using the OS tint color or gray, depending on the button style).
Fri Feb 05, 2016 12:00 pm
roquej offline
Thank you everyone. I knew that it had to be duh moment. No way Indigo had a bug!
JP
