Schedules checking alarmClock
Wed Apr 01, 2015 1:21 pm
MarcoGT offline
Hi all,
I have a variable "alarmClock" which I set (almost) every day to set, of course, the alarm clock for the following day
Idea is to have a schedule running every minute that check if "alarmClock = currentTime"
I thought this was possible using the conditional editor but I was wrong, need to move to the script editor...but the question is: is it AppleScript or Python? In Python should be no problem, something like:
alarmClock = indigo.variables[123]
if alarmClock.value = indigo.getTime()
    indigo.device.turnOn("kitchen_light")
But it seems not working
Any help/hint?
Wed Apr 01, 2015 1:38 pm
MarcoGT offline
Re: Schedules checking alarmClock
I found a workaround using a schedule running every minute which as action contains an embedded Python script checking the variables, but it seems not working
import datetime
alarmClock = indigo.variables[469044268].value
currentTime = indigo.server.getTime()
indigo.server.log(alarmClock)
indigo.server.log(currentTime)
if alarmClock == currentTime:
   indigo.device.turnOn["KitchenLamp"]
Marco
Wed Apr 01, 2015 2:47 pm
MarcoGT offline
I modified again my script and is working
from datetime import datetime
indigo.server.log("Alarm Clock is set at: " + alarmClock)
indigo.server.log("Current time is: " + datetime.now().strftime("%H:%M"))
if alarmClock == datetime.now().strftime("%H:%M"):
   indigo.device.turnOn("KitchenLamp")
Thu May 07, 2015 12:42 am
MarcoGT offline
I would like use the same logic to trigger an action (in this case, a "speak" action) implementing something like this:
if currentTime is between alarmClock and alarmClock+30min, trigger the action
Is it possible in Python?
Sat May 09, 2015 9:16 am
That pseudo script can't trigger - because it's a range. What's causing it to fire? If it's a Trigger or Schedule, then you can just use a time between condition without any scripting.
Sat May 09, 2015 10:03 am
SpencerJRoberts offline
You can also tie it to a real Indigo Schedule and have the code modify the actual execution time of the schedule. That way you don't need to check every minute. I do this for a few different things. Unfortunately it is only possible via applescript as far as I know.
        set myAlarmVar to value of variable "YOUR INDIGO VARIABLE HERE"
        set theSchedule to time date action named "YOUR INDIGO SCHEDULE NAME"
        set date trigger type of theSchedule to everyDay
        set absolute trigger time of theSchedule to date myAlarmVar
end tell
Replace the all-caps text with your info and that should do it, you just need to make sure that your time variable is formatted as "5:00 AM" or "5:15 PM". You may want to add another variable which is actually whether the alarm is enabled or not and make that a condition for the schedule, for the days you don't want it to wake you up.
Wed May 20, 2015 12:33 am
MarcoGT offline
Thanks for the suggestions.
I will modify the logic behind...
