[SOLVED]Can't get Schedules dialog working
Thu Feb 26, 2015 8:41 am
AEshton offline
I created a Schedules event to trigger a siren when motion detected at Sunset every day of the week, but i can not get it working.
Lat/Long of my house and so Sunset/Sunrise time are correct.
I use my Motion Detector for another Triggers Dialog and it works. So my Motion Detector is OK.
When i test my Schedules event after Sunset no notification is seen in the Event Log.
A bug in Indigo or simple a confused user?
Any idea what i should check/do?
Thu Feb 26, 2015 10:22 pm
Re: Can't get Schedules dialog working
I believe the description of what you're looking to do isn't entirely accurate:
That means that exactly at sunset if motion is detected the siren would sound - but I don't believe that's what you mean. So, let's start by clearly describing what it is you want to do, then we can figure out how to implement it.
Fri Feb 27, 2015 9:14 am
AEshton offline
Hi Jay, from your question you are asking me i already have the feeling that i misunderstand the purpose of one of my settings.
This is what i want:
I have a Motion Detector at the front gate.
When it detects someone between Sunset and Sunrise it must trigger a siren.
This must happen everyday in the week.
This is how i set up,
1.Schedules => Schedule => Name: Warning :Time : Sunset
2. Randomize by +/- 7 minutes
3. Date => Days of week => every day SMTWTFS (grey back ground)
4. Repeat => Every week
1.Condition => Any of the following rules are true => if device : Motion Detector : On/Off is On
2. Action s => Type: Turn On (Light/Appliance Control) Device: Siren/Strobe (AM1601)
3. Checked Auto-off after 3 seconds.
There must be a wrong setting somewhere, but i have no idea what setting.
Fri Feb 27, 2015 11:05 am
you must have motion as trigger not as condition. sunrise .. sunset (=dark) is the condition.
create trigger MOTION: trigger if motion, condition dark
that should do it and there should be thousand other ways to do it..
Fri Feb 27, 2015 9:46 pm
Yep, Karl got it right. You don't want to trigger off of Sunset-Sunrise. Rather, you want to trigger off of the motion then associate a condition of "Is dark" (that's between sunset and sunrise) that will keep the actions from firing if it's not dark.
Mon Mar 02, 2015 7:03 am
AEshton offline
Re: [SOLVED]Can't get Schedules dialog working
Thanks Karl and Jay.
Changed my settings as Karl described. Tested thru the weekend and it works as i want to..... :D .
